fuel pump? #1536997
11/19/13 06:16 PM
11/19/13 06:16 PM
68gtx Offline OP
68gtx  Offline OP
68 440 fuel pump? I have a carter M4845 the inlet is 3/8 outlet is 5/16th. The question is did the factory use an adapter for the line out to the separator?? I have not found a pump with an outlet that will allow the outlet line to connect directly to the pump?? Thanks larry J
Re: fuel pump? [Re: 68gtx] #1536998
11/19/13 06:26 PM
11/19/13 06:26 PM
california
Mr D21 Offline
Mr D21  Offline
california
hope this helps...
Re: fuel pump? [Re: Mr D21] #1536999
11/19/13 06:32 PM
11/19/13 06:32 PM
68gtx Offline OP
68gtx  Offline OP
Thanks for the picture. My ? is on your outlet at the fuel pump do you have an adapter between fuel pump outlet and the line to the separator?? So pump adapter line. Or does your line connect directly to your pump? Thanks Larry J
Re: fuel pump? [Re: 68gtx] #1537000
11/19/13 06:35 PM
11/19/13 06:35 PM
california
Mr D21 Offline
Mr D21  Offline
california
adapter ? - there is a hard steel line that bolts to the pump (as shown in the picture) and then a rubber fuel line from the steel line to the separator (again shown in the picture).
Re: fuel pump? [Re: Mr D21] #1537001
11/19/13 06:45 PM
11/19/13 06:45 PM
california
Mr D21 Offline
Mr D21  Offline
california
this might help you...
Re: fuel pump? [Re: Mr D21] #1537002
11/19/13 06:52 PM
11/19/13 06:52 PM
68gtx Offline OP
68gtx  Offline OP
So my metal line out from the pump to the separator should screw right on to the pump without any adapters. The airtex 901 and the carter M4845 both will need an adapter to allow the metal line to connect to the pump. Is the another pump that will allow me to screw the line directly to the pump? Thanks Larry J
Re: fuel pump? [Re: Mr D21] #1537003
11/19/13 06:54 PM
11/19/13 06:54 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
On some pumps there is a square fitting on the bottom, a pipe thread reducer with a flare is into that, then the 5/16 hard line.
Joe
Re: fuel pump? [Re: 68gtx] #1537004
11/19/13 07:01 PM
11/19/13 07:01 PM
california
Mr D21 Offline
Mr D21  Offline
california
The 2nd picture I posted is a correct pump with the correct outlet already part of the pump.
Re: fuel pump? [Re: Mr D21] #1537005
11/19/13 08:34 PM
11/19/13 08:34 PM
maine
LO23 Offline
LO23  Offline
maine
yes there is an adapter. i just bought the same pump. it needs a female inverted adapter.
Re: fuel pump? [Re: LO23] #1537006
11/19/13 08:58 PM
11/19/13 08:58 PM
68gtx Offline OP
68gtx  Offline OP
I think the issue I am having is the repop line is 3/8s. and not 5/16ths can I assume the original line outlet is 5/16ths. Thanks Larry J
Re: fuel pump? [Re: Mr D21] #1537007
11/19/13 08:58 PM
11/19/13 08:58 PM
New Mexico
JMCFAN Online content
JMCFAN  Online Content
New Mexico
hope this helps...
Boy I wold love to see some more photos of that motor...
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: fuel pump? [Re: JMCFAN] #1537008
11/19/13 09:03 PM
11/19/13 09:03 PM
california
Mr D21 Offline
Mr D21  Offline
california
another
Re: fuel pump? [Re: 68gtx] #1537009
11/19/13 09:09 PM
11/19/13 09:09 PM
maine
LO23 Offline
LO23  Offline
maine
this is the pump you want-hes moparts member. the napa pump has a male receiver, needing the adapter. and yes the line would have been 5/16.
http://www.ebay.com/itm/Mopar-Hemi-440-F...#ht_1767wt_1124
Re: fuel pump? [Re: LO23] #1537010
11/19/13 09:18 PM
11/19/13 09:18 PM
california
Mr D21 Offline
Mr D21  Offline
california
he has the wrong fuel line - I think that's the issue...
Re: fuel pump? [Re: JMCFAN] #1537011
11/20/13 09:32 AM
11/20/13 09:32 AM
Land of 10,000 Lakes
44D6PAKCUDA Offline
44D6PAKCUDA  Offline
hope this helps...
I could send you some more,but the car is "put away" for the winter.Remind me in the spring and I can send you some additional ones.Those other pictures are from Frank Badalsons display when he had my motor at Carlisle a few years back.
Re: fuel pump? [Re: 44D6PAKCUDA] #1537012
11/20/13 12:01 PM
11/20/13 12:01 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Here is the piece you need. Y-One has them...probably others as well.
Re: fuel pump? [Re: FJ5_Fish] #1537013
11/20/13 12:34 PM
11/20/13 12:34 PM
68gtx Offline OP
68gtx  Offline OP
Did the factory use the adapter?? Or did the line connect directly to the fuel pump without and adapter?? Either I have the wrong line or the wrong pump or the factory used the adapter and all of my parts are correct?? I have a Carter M4845. And reproduction lines which the line that connects directly to the fuel pump outlet is 3/8 is it suppose to be 5/16ths?? Thanks Larry J
Re: fuel pump? [Re: 68gtx] #1537014
11/20/13 12:52 PM
11/20/13 12:52 PM
68gtx Offline OP
68gtx  Offline OP
I realize i can use an adapter. The real ? for me is did the factory use an adapter??? Thanks larry j
Re: fuel pump? [Re: 68gtx] #1537015
11/20/13 01:00 PM
11/20/13 01:00 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
By looking at the first picture, the inlet uses KV- hose which is 3/8". The hose connected to the outlet line is just KV. That is 5/16". It looks to me like the outlet line is 5/16". I think you have the wrong line.
Re: fuel pump? [Re: burdar] #1537016
11/20/13 01:19 PM
11/20/13 01:19 PM
california
Mr D21 Offline
Mr D21  Offline
california
Larry - you have either the wrong pump or the wrong fuel line. Either way, there is NO adapter from the factory.
Sounds like in your case an adapter will be an easy and quick fix if you don't care about factory correctness...
