Why the different sounding starters?? #153693
11/19/08 10:58 PM
11/19/08 10:58 PM
Glendale, AZ
69L78Nova Offline OP
Banned. Forever.
Banned. Forever.
Glendale, AZ
The reman starter on my 78 Fury sounds like a slant six starter. Every V8 from 1975 and up has a different sound than the 74-older. The older ones seem to crank slower and have more of a slant six sound to them. It drives me crazy. I dont want to put a mini starter on it. I want it to sound right. It bugs me that much! Can anyone explain this?
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Why the different sounding starters?? [Re: 69L78Nova] #153694
11/19/08 11:12 PM
11/19/08 11:12 PM
Hunt Valley, Maryland
1fastrunner Offline
1fastrunner  Offline
I put a mini starter on my car and it sounds different. It claims to have more torque and spin faster.
Re: Why the different sounding starters?? [Re: 1fastrunner] #153695
11/19/08 11:16 PM
11/19/08 11:16 PM
Glendale, AZ
Banned. Forever.
Banned. Forever.
Glendale, AZ
I have many mini starters. I refuse to use them simply because of the sound. They sound like a newer Chevy or import
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: Why the different sounding starters?? [Re: 69L78Nova] #153696
11/19/08 11:19 PM
11/19/08 11:19 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
True, but they are really more efficient. I actually hardly hear my starter, maybe a full second when starting up. Lights up quick
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Why the different sounding starters?? [Re: GoodysGotaCuda] #153697
11/19/08 11:36 PM
11/19/08 11:36 PM
Glendale, AZ
Banned. Forever.
Banned. Forever.
Glendale, AZ
Does anybody know?
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: Why the different sounding starters?? [Re: 69L78Nova] #153698
11/20/08 12:12 AM
11/20/08 12:12 AM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
I'll help the best I can. I work with motors quite a
bit. So it's all based on the number of "poles" in the magnetic field that drive the motor. More number of poles faster motor turns. Now all that said, it can also depend on current, strength of the stator, rotor clearance etc.
I would check a couple
of things to make sure your contacts are good. First look at the large threaded copper stud where
the batter cable goes. Make sure it's not worn down
or corroded. Rebuild houses are great for reusing
suspect parts to save a buck.
Re: Why the different sounding starters?? [Re: Dart 340] #153699
11/20/08 01:16 AM
11/20/08 01:16 AM
CENTRAL MINN
1965_PLYMOUTH Offline
CENTRAL MINN
also, right around that time period, they went to a different number tooth pinion that turns your armature over. I've rebuilt quite a few MOPAR starteres in my day, and the older and later have some non-interchangeable pieces. the older ones also have a heavy wire inside the starter soldered, and the later ones have a little bolt connection. this heavy wire almost looks like a tiny cable.
I hope this helps.
Re: Why the different sounding starters?? [Re: 69L78Nova] #153700
11/20/08 05:07 AM
11/20/08 05:07 AM
Indiana
P
Pentastar440 Offline
P
Indiana
It's the older gear reduction starters that had that MoPar sound.
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
Re: Why the different sounding starters?? [Re: 69L78Nova] #153701
11/20/08 10:42 AM
11/20/08 10:42 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
The longer older style starters sounded different then the short bodied older starters.
Re: Why the different sounding starters?? [Re: buildanother] #153702
11/20/08 12:23 PM
11/20/08 12:23 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
I thought slant to Hemi was the same starter?
You must have sensitive ears...
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Why the different sounding starters?? [Re: Rug_Trucker] #153703
11/20/08 01:35 PM
11/20/08 01:35 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
I love the sound of the older starters too. But I also find some sound different than others. I have a slant starter (has a shorter body I think?) on a 10:1 360 that spins much faster than the one on my '67 440.
4826586-starter.mp3 (42 downloads)
Re: Why the different sounding starters?? [Re: 440newport] #153704
11/20/08 04:46 PM
11/20/08 04:46 PM
Pa
K
koak Offline
koak  Offline
K
Pa
I actually removed a starter from truck I had to use in my 'Cuda because it had that perfect old Chrysler sound. It was a reman, but the housing was an older casting. I agree sometime around '74-'75 they changed sound. I like the older ta ta ta sound personally just because it is right for the car.
Re: Why the different sounding starters?? [Re: koak] #153705
11/20/08 04:49 PM
11/20/08 04:49 PM
Pa
K
koak Offline
koak  Offline
K
Pa
Oh yeah, I know the '75 and up were rated at a higher HP. Probably whatever changes were made to achieve that changed the sound....
Re: Why the different sounding starters?? [Re: koak] #153706
11/20/08 06:54 PM
11/20/08 06:54 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Beginning in 75,360 and up got the 1.8hp starter,/6 and 318 still used the 1.5hp starter.
Re: Why the different sounding starters?? [Re: 62maxwgn] #153707
11/20/08 07:06 PM
11/20/08 07:06 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
I like the mini starter because it doesn't take 2 hours to put in like the huge original one.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Why the different sounding starters?? [Re: goldduster318] #153708
11/20/08 08:00 PM
11/20/08 08:00 PM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
The tinny "slant six" starter sound is made by the light duty 1.5 horsepower starter whereas the V8 sound is from the HD 1.8 horsepower unit.
They sound different because they`re different internally with a much different reduction ratio, bigger, faster motor, shock cushioned drive pinion and a pinion brake that stops the pinion from rattling on after the engine starts.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: Why the different sounding starters?? [Re: gamagoat6x6] #153709
11/20/08 08:05 PM
11/20/08 08:05 PM
Glendale, AZ
Banned. Forever.
Banned. Forever.
Glendale, AZ
Wow, thanks chums! I now know what to look for when I go to buy a new starter. I need the "HD" unit with a longer case. I appreciate all the replies
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: Why the different sounding starters?? [Re: goldduster318] #153710
11/21/08 03:06 PM
11/21/08 03:06 PM
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
I'm with you. Especially on an A body with headers.
Also, with the higher compression I am running, the
engine turns over MUCH faster, I don't have heat
soak problems, and it's half the weight. I can live
with the sound. Funny how guys don't like the starter sound but will hack their exhaust. I've met
a few of those.
Re: Why the different sounding starters?? [Re: Dart 340] #153711
11/21/08 08:11 PM
11/21/08 08:11 PM
Glendale, AZ
Banned. Forever.
Banned. Forever.
Glendale, AZ
a few of those.
Funny...I dont have to hack the exhaust on my Barracuda to use either the big starter or the mini. Small block, headers, and a 4-speed...cluttered with clutch linkage! Have a nice day!
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: Why the different sounding starters?? [Re: 69L78Nova] #153712
11/21/08 08:33 PM
11/21/08 08:33 PM
New York City
groundpoint6 Offline
New York City
Koak is right. In 1975 Chrysler went to a higher horse power starter on all 8 cyl engines 360 cid and higher. The starter was 3/4 inch longer than the regular starter. Back in 75 while working for Chrysler, I let`s say got my hands on a brand new one out of a 75 Imperial and installed it in my 70 RR. The reason it sticks out in my mind is that I had to heat up any bend my header to accept the 3/4 inch longer starter.
