Switching from power brakes to manual #1534481
11/17/13 08:24 PM
11/17/13 08:24 PM
White House,TN
stroked470 Offline OP
White House,TN
I just got a 75 Dart with power brakes. I don't like them and want to change to manual. What all is needed. Will a manual master cylinder and pushrod be enough for the swap.
Re: Switching from power brakes to manual [Re: stroked470] #1534482
11/17/13 09:27 PM
11/17/13 09:27 PM
Az
Crizila Offline
Crizila  Offline
Az
Not much info here, but if you are running the stock disc / drum system, you might get away with just buying a master adaptor kit and adjustable push rod. I made this switch on my 79 Cordoba. Had some real weird Z bar linkage between the brake pedal arm and booster. I redrilled the pedal arm for the adjustable pushrod and used 2" as the distance between the arm pivot point and push rod mounting hole in the pedal arm. Worked fine. A little heavier pedal pressure, but not bad at all.
Fastest 300
Re: Switching from power brakes to manual [Re: Crizila] #1534483
11/17/13 09:28 PM
11/17/13 09:28 PM
Az
Crizila Offline
Crizila  Offline
Az
pushrod mount
Fastest 300
Re: Switching from power brakes to manual [Re: Crizila] #1534484
11/17/13 09:33 PM
11/17/13 09:33 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
On my Dart Sport i swapped out the master cylinder with the newer unit with the plastic reservoir from Mancini Racing and used their adjustable pushrod. I removed the metering block and indtalled an adjustable one in the rear line. Works very well.
Randy
Re: Switching from power brakes to manual [Re: stroked470] #1534485
11/17/13 09:56 PM
11/17/13 09:56 PM
AndyF Offline
AndyF  Offline
www.doctordiff.com has everything you need.
Re: Switching from power brakes to manual [Re: stroked470] #1534486
11/18/13 10:09 AM
11/18/13 10:09 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
At bare minimum, all you need is the pushrod. You can re-use your existing master cyl. assuming you aren't, say converting from manual to disc at the same time as removing the booster. It will bolt in place of the booster. PM me if you need the pushrod.
