B Body 1970 AM-FM Radio ID #153433
11/19/08 05:14 PM
11/19/08 05:14 PM
TX , NJ , FL
W
WINGCARS_6970 Offline OP
W
TX , NJ , FL
I think the paper tag from up top is gone.Does anyone have radio ID codes.What other numbers found on it would better identify it.As being for a Dodge or Plymouth.Or Coronet Or Charger.But I think its from a 70 Dodge Coronet.
http://i20.photobucket.com/albums/b229/Annie75414/100_4177.jpg
http://i20.photobucket.com/albums/b229/Annie75414/100_4175.jpg
1969 Daytona 440 L9B410772 1970 Coronet 500 383 Presently owned 1970 Superbird 440 U 166242 1970 Superbird 440 U 174597 1970 Superbird 440-6 V 179697 1970 Coronet RT 440 U 224126 1968 Road Runner 426 J 134509 1970 Daytona Replica 318 G 178701
Re: B Body 1970 AM-FM Radio ID [Re: WINGCARS_6970] #153434
11/19/08 05:16 PM
11/19/08 05:16 PM
swamps of florida
beepsalot Offline
beepsalot  Offline
swamps of florida
70 chrysler or plymouth b body. i know it sounds strange, but alot the the plymouth radios had chrysler on them. face plate is off of a rallye cluster, also b body
Just Follow Me Down the Street, You'll Know i'm Up to No Good...
Re: B Body 1970 AM-FM Radio ID [Re: WINGCARS_6970] #153435
11/19/08 05:17 PM
11/19/08 05:17 PM
Haslett, MI
7DRRunner Offline
7DRRunner  Offline
Haslett, MI
Looks like a '70 to me
here's mine
"Good luck on your project." 1970 Road Runner "Accellertii Incredibus"
Re: B Body 1970 AM-FM Radio ID [Re: 7DRRunner] #153436
11/19/08 05:19 PM
11/19/08 05:19 PM
Haslett, MI
7DRRunner Offline
7DRRunner  Offline
Haslett, MI
another / bottom shot
Re: B Body 1970 AM-FM Radio ID [Re: 7DRRunner] #153437
11/19/08 05:21 PM
11/19/08 05:21 PM
TX , NJ , FL
W
W
TX , NJ , FL
Yours looks similar except for the knobs.Just want know its right for example a 70 Charger.If someone with a 70 charger is looking
Re: B Body 1970 AM-FM Radio ID [Re: WINGCARS_6970] #153438
11/19/08 05:26 PM
11/19/08 05:26 PM
Haslett, MI
7DRRunner Offline
7DRRunner  Offline
Haslett, MI
whoooops
I forgot
the AM radio that was in there, and it had those knobs
when I found this one, it had the black knobs
I was trying it out to see which way I liked it ...
Re: B Body 1970 AM-FM Radio ID [Re: 7DRRunner] #153439
11/19/08 05:34 PM
11/19/08 05:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
whoooops
I forgot
these are the correct knobs , the others i have never seen in a 70 b body on any radio
Re: B Body 1970 AM-FM Radio ID [Re: JohnRR] #153440
11/19/08 05:37 PM
11/19/08 05:37 PM
Haslett, MI
7DRRunner Offline
7DRRunner  Offline
Haslett, MI
I don't know where they came from .... the previous owner may have put them on there ...
here's the AM that came with the car ..
Re: B Body 1970 AM-FM Radio ID [Re: beepsalot] #153441
11/19/08 05:59 PM
11/19/08 05:59 PM
MN
mnguy55 Offline
mnguy55  Offline
MN
They said Chrysler Solid State whether they were in a Chrysler, Dodge or Plymouth.
Re: B Body 1970 AM-FM Radio ID [Re: mnguy55] #153442
11/19/08 07:06 PM
11/19/08 07:06 PM
Alabama
BigMoneyLewis Offline
Alabama
That is a correct 1970 B body AM FM .It is correct for
Charger, Superbee , Coronet, Satellite, Road Runner, GTX etc.
ALL 1970 B body AM FM radios will say "Chrysler" on the dial face.
Of all the Mopar radios, this one is the "king" .
Greg
Wards Classic Car Radio Repair Specializing in restoration and sales of Mopar A B E body radios
We can restore YOUR radio usually in less than 7 days
Visit our NEW website..
http://www.wardsclassiccarradiorepair.com
gregward@mchsi.com
phone 256-852-0955
gregward@mchsi.com phone 256-852-0955
Re: B Body 1970 AM-FM Radio ID [Re: BigMoneyLewis] #153443
11/19/08 07:34 PM
11/19/08 07:34 PM
Alabama
Alabama
While we are on the subject , lets take a few moments to review some of the unique features of a
1970 B body radio. Typically, the AM FM will be part # 2884753 . Although this radio chasis is very simular to the 70-up A bodies , there are several distinctive features found only on the 1970 B body . The lense , for example, is a "stepped" lense (not a flat lense) and the upper section will be painted black. The push buttons are black and unique in that they have a square opening facing UP . This is the only Mopar radio to have BLACK buttons and squares facing UP.
Also note the alignment pins on the front housing
and the holes for the mounting bolts on the front. The knob shaft surrounds are NOT threaded .
Greg
gregward@mchsi.com
phone 256-852-0955
Re: B Body 1970 AM-FM Radio ID [Re: BigMoneyLewis] #153444
11/19/08 07:48 PM
11/19/08 07:48 PM
Alabama
Alabama
Now, lets compare and contrast a 70-up A body AM FM . Because the chasis and dimensions are very simular, many people are easily mislead into buying a much more common A body radio.This radio pictured below is NOT correct for 1970 B body, but is very often mistaken as such. The unit pictured below is a "dime a dozen " A body .
Lets take note of some of the differences.
For example, notice the flat lense . Also take note that the push buttons, although black, are smooth on top and do not have the square openings. The A body does not have alignment pins on front, nor does it have the holes for the mounting bolts on front. In contrast, it has threaded knob shaft surrounds that the B body does not have.
Those are just a few of the differences that will help you, when out shopping for a "real deal" 1970 B body AM FM.
The 70 B am fm is a pretty tough radio to find.
To give you an example, most people consider the 1968-9 B body AM FM thumbwheel to be "rare" . We see probably 10 times as many of those come in for service than the "elusive" 1970 units .
Greg
gregward@mchsi.com
phone 256-852-0955
Re: B Body 1970 AM-FM Radio ID [Re: BigMoneyLewis] #153445
11/19/08 08:36 PM
11/19/08 08:36 PM
TX , NJ , FL
W
W
TX , NJ , FL
Thanks for your help and radio education
Re: B Body 1970 AM-FM Radio ID [Re: WINGCARS_6970] #153446
11/20/08 01:32 AM
11/20/08 01:32 AM
CENTRAL MINN
1965_PLYMOUTH Offline
CENTRAL MINN
7DRRunner; looks like your knobs come from 72-73 fullsize or van???
Re: B Body 1970 AM-FM Radio ID [Re: WINGCARS_6970] #2277443
03/27/17 11:55 PM
03/27/17 11:55 PM
IN
Mopar Robert Offline
IN
Mopar radios can be tough to tell apart with all of the different bodies but I think its a 1970 B Body. Mopar Radio
