Re: Did WJ really say ??? ..... [Re: Challenger 1] #1534249
11/18/13 06:39 PM
11/18/13 06:39 PM
Texas Afghanistan Iraq etc.
DakFink Offline
DakFink  Offline
I read somewhere that when the Pro Stock Trucks were running. Those teams were spending $40000-50000/yr on springs alone. Again 1-2 passes and done. 10500-11000 rpms per pass.
Re: Did WJ really say ??? ..... [Re: DakFink] #1534250
11/18/13 06:54 PM
11/18/13 06:54 PM
Camp Point, IL
gofish Offline
gofish  Offline
Camp Point, IL
What are the differences between valvetrain in NASCAR engines versus drag racing? Is it simply difference in application? Tractor pulling is another sport that runs some big RPM for much longer than drag racers.
Danny
Re: Did WJ really say ??? ..... [Re: gofish] #1534251
11/18/13 07:25 PM
11/18/13 07:25 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
From what I know (outsider perspective), if you're comparing NASCAR with NHRA Pro Stock, there are big difference in: peak valve lift, rate of lobe acceleration, valve train weights, and durability expectations, just to name what I can think of.
The late Smokey Yunick said something in one of his books decades ago about how he didn't know how pro drag race engines managed to keep their valve train together even for such short runs, because even way back then the drag engines were already pushing the envelope well past where circle track engines dared go.
Re: Did WJ really say ??? ..... [Re: BradH] #1534252
11/18/13 07:29 PM
11/18/13 07:29 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I wonder how nascar can turn 10k plus for 600+ miles
Re: Did WJ really say ??? ..... [Re: dOc …] #1534253
11/18/13 07:29 PM
11/18/13 07:29 PM
..... I was SURE he said 200k$ on valve springs during a season of racing .... BUTTT did he actually say that a rear end housing was 250k$ .... JUST for the empty housing ? .... What-the-fugg ....
Didn't one of the Summit drivers, Jason or Greg say they where spending $100,000.00 a year on valve springs several races back on T.V. If so maybe Warren is courting another sponsor and is padding the numbers to enhance the operating expences for the sponsorship budget
Re: Did WJ really say ??? ..... [Re: Quicktree] #1534254
11/18/13 07:36 PM
11/18/13 07:36 PM
BradH Offline
BradH  Offline
They work closely with their cam company's engineers and live and die by the SpinTron. They use all the latest-and-greatest stuff, even if it is still a flat-tappet setup: lower lobe lifts, higher rocker ratios, DLC-coated lifters, welded cam cores for hardness, etc.
It's pretty trick stuff for "just a bunch of solid lifter cams", eh?
Re: Did WJ really say ??? ..... [Re: gofish] #1534255
11/18/13 07:50 PM
11/18/13 07:50 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
Danny
camshaft profiles, engine speed, component weight to name a few
Re: Did WJ really say ??? ..... [Re: Cab_Burge] #1534256
11/18/13 07:53 PM
11/18/13 07:53 PM
Florida STAYcation
dOc … Online penguin-006 OP
The village idiot's idiot
dOc …  Online Penguin-006 OP
Florida STAYcation
Padding the numbers ? .,.,, that was on another topic here a day or so ago !! ...
I think AJ said the # 125 or 150 in a past interview.
Re: Did WJ really say ??? ..... [Re: BradH] #1534257
11/18/13 07:55 PM
11/18/13 07:55 PM
New York
polyspheric Offline
polyspheric  Offline
New York
They should just compare bank statements.
Boffin Emeritus
Re: Did WJ really say ??? ..... [Re: Quicktree] #1534258
11/18/13 08:04 PM
11/18/13 08:04 PM
Camp Point, IL
gofish Offline
gofish  Offline
Camp Point, IL
NASCAR engines do not stay at peak RPM for the full race, they are up and down, some races RPM varies a lot, some not so much. I agree though, a Pro Stock motor cant get a mile or 2 out of valve springs versus several hundred out of a NASCAR set, something is vastly different. I am sure NASCAR does not put quite as much emphasis on how fast the engine accelerates.
What horsepower per cubic inch does a NASCAR engine make? Just over 2? A Pro Stock motor makes almost 3, so I guess some the extra power is made at the sacrifice of valvetrain longevity.
Danny
Re: Did WJ really say ??? ..... [Re: gofish] #1534259
11/21/13 02:13 AM
11/21/13 02:13 AM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Lets do some math. Lets say we are a really good team and we average 6 runs per event and we change after every 2 passes. 1600 X 3 = 4800 per event X 23 (I dont remember how many) events = $110400 just for the races. Now lets figure in all the hours they run on the dyno and in testing. I'll bet that is as much or more than the amount of actual runs. But if we simply double the cost then we still come up with $220,000. Im guessing WJ's figures are correct.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Did WJ really say ??? ..... [Re: Irun5snd8th] #1534260
11/21/13 03:00 AM
11/21/13 03:00 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Pro Stock camshafts are FAR more radical in intensity, opening/closing rates, etc., the spring controls more weight and peak rpm is over 1000rpm higher.....among other things.
Between R&D, test runs, qualifying and eliminations, I have no doubt the cost is in the 100s of 1000s for an entire season.
