Need help with brake light switch #1532716
11/12/13 08:19 PM
11/12/13 08:19 PM
Southern CA
Colin Frolick Offline OP
Southern CA
Hello and thanks for looking
my '71 imperial has a bad brake light switch
it looks like this
i can find similar enough switches, but none with the pigtail.
any ideas on where to get one or another part I could use?
thanks for the help moparts
Re: Need help with brake light switch [Re: Colin Frolick] #1532717
11/12/13 08:48 PM
11/12/13 08:48 PM
i can find similar enough switches, but none with the pigtail. any ideas
You might solder on a new pigtail/connector (even if slightly different) to your new similar switch. Or even a different type of male/female connector(s) at the end of the pigtail if need be
Re: Need help with brake light switch [Re: RapidRobert] #1532718
11/12/13 09:30 PM
11/12/13 09:30 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
That looks like a cruise control equipped brake light switch which is different than a non cruise car. You can do what Robert said and just add the right connectors to the pig tail to attach it to a replacement 4 terminal switch.
Re: Need help with brake light switch [Re: Colin Frolick] #1532719
11/12/13 09:59 PM
11/12/13 09:59 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Standard pt #SLS99
Re: Need help with brake light switch [Re: gtx6970] #1532720
11/12/13 11:26 PM
11/12/13 11:26 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Chrysler part# is 2947798, in case you want to go for an NOS one.
http://www.ebay.com/dsc/i.html?_from=R40...8&_osacat=0
Probably easier/cheaper though, to get the aftermarket one shown above by gtx6970.
Re: Need help with brake light switch [Re: gtx6970] #1532721
11/13/13 03:29 AM
11/13/13 03:29 AM
Southern CA
Southern CA
nice nice thanks for the help everybody
