c body power window regulators in b body #1531483
11/10/13 08:40 PM
11/10/13 08:40 PM
yellow70charger Offline OP
I have a 70 chrysler town and country station wagon(in junk yard) that has power windows. Does anyone think if I remove the front door regulators could I use in my 70 B body charger with or without modification. I know the harness wouldn't be correct but would work i could save the rear window motors and just have to find rear regulators thanks James
Re: c body power window regulators in b body [Re: yellow70charger] #1531484
11/11/13 01:48 AM
11/11/13 01:48 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I am curious too..Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: c body power window regulators in b body [Re: astjp2] #1531485
11/11/13 02:33 PM
11/11/13 02:33 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
They are totally different motors. I took some out of a new Yorker that I parted out just to have in case my Charger ever needed them since my Charger has factory power windows. When I finally got a chance to compare them one day they were totally different in design, the way they mounted & the plugs/harnesses were totally different.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: c body power window regulators in b body [Re: 6PKRTSE] #1531486
11/11/13 06:32 PM
11/11/13 06:32 PM
Ok thought i got lucky
Thank youfor your input
Re: c body power window regulators in b body [Re: 6PKRTSE] #1531487
11/12/13 05:03 AM
11/12/13 05:03 AM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
Is this true for front and rear? The front regulators look pretty much the same except the additional bar in the middle of the arm. Removing the bar shouldn't be a problem... don't know if the dimensions are different though..
Re: c body power window regulators in b body [Re: DGS] #1531488
11/12/13 07:53 PM
11/12/13 07:53 PM
People's Republic of Kali
70runner Offline
70runner  Offline
Seems to be a blend of two things in this thread, regulators and motors. My experience is largely centered on B bodies, restoring a 69B&70B OE PW system, converting a 70B from manual to PW, and rebuilding PW switches.
Re the regulators, AFAIK very few if none of these will interchange between models, power or otherwise, due to the door/glass geometry variations. Regulators for the same year/model will typically be different part nos between convertible and hardtop.
Re motors, again - in my experience, I've used motors from C bodies as well as 81-85 junkyard Chryslers (which are still plentiful) on B bodies. IIRC in late 80s Chrysler redesigned the PW motors and they will not interchange with the older guys.
