Re: question about welding on rearend
[Re: 80arrow]
#1531157
11/10/13 11:07 AM
11/10/13 11:07 AM
Posts: 22,696 Bitopia
jcc
Bitopia
I assume, there will no weight on the car. I suspect it might work fine, worse case is to cut off ends and reweld with alignment bar. The biggest problem to me is how much effort you need to undertake to see if the housing warped after welding, and maybe just bite the bullet and do it right once. I hope we hear the success rate in this process from others.
[Re: Quicktree]
#1531158
11/10/13 11:15 AM
11/10/13 11:15 AM
Posts: 814 in front of the computer
80arrow
I tip my shocks about 10* to the front. you should be ok to weld a little at a time on the mounts. I have done it before. is it cold up there yet?
Yes it is, we have a couple inches of snow up here . I'll tip them towards the front a little to then, thanks.
[Re: jcc]
#1531159
11/10/13 11:20 AM
11/10/13 11:20 AM
80arrow
You are correct, there is no weight on the car. I wouldn't check it after welding, if the tires start to wear funny then I would cut the ends off and use a bar I guess. If I had a bar I would use it but I don't
