Re: E-body front suspension question
[Re: 340swing]
#1530951
11/09/13 10:12 PM
11/09/13 10:12 PM
RapidRobert
to the back. iirc someone way back had this problem & the idler and or the pitman arm(s) did not have the same bend/depth as what come off of there
[Re: 340swing]
#1530952
11/09/13 10:21 PM
11/09/13 10:21 PM
Posts: 18,160 Mass
DAYCLONA
Mass
I'm installing all new front end parts on my 70 cuda. I purchased all the parts from springs and things. All the parts are mcquaid/norris parts. The left inner tie rod hits the torsion bar. Has any body seen this? I'm not sure on the center link does the curved end go towards the back of the car or front. I have it towards the back not sure if it will make a difference in clearance.
center link orientation 70 Challenger/ref., did you change the pitman/steering arm?
[Re: 340swing]
#1530954
11/10/13 01:16 AM
11/10/13 01:16 AM
Posts: 18,160 Mass
DAYCLONA
Mass
Ok I have the center link in right but the idler and the pitman arms are new. Both from springs and things I guess I will call them. I have the originals I will match them up and see if i can find the problem. Thanks
I'd match the pcs up as you stated, I've only used the McQuay/Norris front end kits once, and was disappointed in the quality that they bragged(advertised) about in their components...inspect all the components carefully
[Re: DAYCLONA]
#1530955
11/10/13 11:36 AM
11/10/13 11:36 AM
Posts: 313 Ct, Oxford
340swing
Ct, Oxford
Ok the pitman arm is the problem. It's a little longer. The idler arm looks good. I will call espo springs and things Monday to see if they sent the wrong one or if they have an alternative. Thanks for the responses.
[Re: 340swing]
#1530957
11/10/13 12:15 PM
11/10/13 12:15 PM
RapidRobert
I would want one with the same length/bend/offset as the original (& of good quality). It was not hitting with the OE one so I'd want to exactly duplicate that to return to that condition. EDIT some Moog stuff may be made in China now
[Re: jt4406]
#1530959
11/10/13 12:41 PM
11/10/13 12:41 PM
Posts: 18,160 Mass
DAYCLONA
Mass
the splined area is off set on the original and centered on the new one
You guys correct me if I am wrong, but I believe this would not be as important a feature as the actual measured distance from the center of the hole to the center of the pivot on the other end that drops into the center link, comparing parts to each other. just my I believe you should turn them sideways and compare amount of drop from box splined end to pivot end also. jess
Correct,...importance is how much difference is there in the side profiles, length, drop, and angle of the rod end in relation to the open spline end plane geometry of the two, as this will effect the height of the installed centerlink
[Re: DAYCLONA]
#1530960
11/10/13 01:08 PM
11/10/13 01:08 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
Hate to tell you but I used to sell Mcquaid/Norris back in the 70's and it was junk back then and probably still is now from what I've heard. Don't except much life out of the ball joints and rod ends. We had to drop them cause of all the returns and failures. I had terrible luck with them several times myself. This was back when their stuff was made in the USA. Just sayin.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: 340swing]
#1530966
11/11/13 04:24 PM
11/11/13 04:24 PM
340swing
Ct, Oxford
2nd inner tie rod hitting torsion bar
