KB Street Hemi Block Oiling #1530444
11/09/13 09:49 AM
11/09/13 09:49 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
How are you guys getting your oil up in your KB Street Hemi block?
There's no holes in the cam journal area.
And do you recommend bronze lifter bores in a aluminum block?
Re: KB Street Hemi Block Oiling [Re: Sammy] #1530445
11/09/13 11:01 AM
11/09/13 11:01 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
By "up" I assume you mean up to the heads/rockers. Was the block drilled for Hydraulic lifters? It was the only extra cost item when I ordered my block. I had it done so I could use push rod oiling for the top end.
Re: KB Street Hemi Block Oiling [Re: Bigcube] #1530446
11/09/13 02:33 PM
11/09/13 02:33 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
No, it was not drilled for hydraulic lifters.I got a external oiling kit from Ray Barton to go from the side of the block up to the lifter galley behind the bellhousing area with -3an braided line and fittings. Tap that with 1/8" threaded T fitting and from inside go to each side of the Barton T &D rocker shaft.
Not sure if I need anything else.
Re: KB Street Hemi Block Oiling [Re: Sammy] #1530447
11/09/13 10:03 PM
11/09/13 10:03 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Were using -13 wedge heads with the spray bars on a KB block. I know a lot of folk prefer pushrod oiling but we've never had a problem in over 10 years.
-3 line from the side of the block then to a t piece and the fitting (restricted) on the valve cover to the spray bars.
Re: KB Street Hemi Block Oiling [Re: Tig] #1530448
11/09/13 10:18 PM
11/09/13 10:18 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Where is your restrictor located in the line?
This is good to know. This will be the first time I'm not using pushrod oiling and need to figure out which lifter to use.
Re: KB Street Hemi Block Oiling [Re: Sammy] #1530449
11/10/13 06:02 PM
11/10/13 06:02 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
The restrictor is located in the t piece that goes to the valve cover. The T piece is tapped and a drilled grub screw is fitted. Don't know what size it is drilled, comes with the Indy kit.
HTH's Tig
Re: KB Street Hemi Block Oiling [Re: Tig] #1530450
11/10/13 06:33 PM
11/10/13 06:33 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
HTH's Tig
You got any pictures of your indy kit.
Mine is from Ray Barton.I think they are different.IIRC
Re: KB Street Hemi Block Oiling [Re: Sammy] #1530451
11/10/13 07:38 PM
11/10/13 07:38 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Old pic but you can follow the lines if you look hard
Re: KB Street Hemi Block Oiling [Re: Tig] #1530452
11/11/13 11:23 AM
11/11/13 11:23 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
If you use the stock type hemi rockers it will be easier. Everything is already set up for that.
2011 Drag Pak Challenger
