440 in a 68 Dart adding an alternator #1530433
11/09/13 01:48 AM
11/09/13 01:48 AM
So. Calif
a68dart360 Offline OP
So. Calif
I have a 68 Dart with a 440 mounted with a motor plate and I want to put an alternator on it. Does anyone have any pictures of how they mounted the alternator to the front of the engine. Is there a kit that a company sells for this application. I have a miezere type water pump on the engine so I do not have a water pump pulley. It would only drive off the crank pulley.
1968 Dodge Dart GTS factory big block car that I race at the track.
Re: 440 in a 68 Dart adding an alternator [Re: a68dart360] #1530434
11/09/13 01:55 AM
11/09/13 01:55 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Is it a street car or drag car? I have mounted an alternator off the rear end before. Also, you should be able to still use the stock alternator mounts, but you either have to mill the water pump housing down to have the pulley's the same location as stock, or press the alternator pulley on at the location of the crank pulley and find a belt that will work.
JB Rhinehart, Realist
A-Body's RULE!
Re: 440 in a 68 Dart adding an alternator [Re: Rhinodart] #1530435
11/09/13 02:37 AM
11/09/13 02:37 AM
So. Calif
So. Calif
it's a track car but maybe drive it on the street to a burger stand for a cruise night or car show but not that often.
Re: 440 in a 68 Dart adding an alternator [Re: a68dart360] #1530436
11/09/13 03:47 PM
11/09/13 03:47 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Use factory brackets and put a spacer the thickness of motor plate behind the crank pulley. Just run a belt from the crank to the alt.
Re: 440 in a 68 Dart adding an alternator [Re: a68dart360] #1530437
11/09/13 06:22 PM
11/09/13 06:22 PM
AndyF Offline
AndyF  Offline
I've sold a kit for that application for a number of years. Mancini Racing and Hughes Engines should have it on hand.
