Avs three barrel mod #1530077
11/08/13 12:47 PM
11/08/13 12:47 PM
Texas
dannysbee Offline OP
Texas
I was reading an old carter tuning guide that I have and it showed pictures of an old nascar afb that was a three barrel. Said they were quite rare. Wonder if any one had modified a four barrel afb or avs to 3 barrel for fast.
Getting old just means you were smarter than some and luckier than others.
Re: Avs three barrel mod [Re: dannysbee] #1530078
11/08/13 02:17 PM
11/08/13 02:17 PM
Texas
Texas
It was rated over 900 cfm
Re: Avs three barrel mod [Re: dannysbee] #1530079
11/08/13 03:15 PM
11/08/13 03:15 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
interesting. i don't remember anything like that back in the day, but somebody could've got creative. got any pics?
Re: Avs three barrel mod [Re: lewtot184] #1530080
11/08/13 03:35 PM
11/08/13 03:35 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Years ago there was a Hot Rod magazine with a yellow Mustang on the cover that was air born over a hill. I remember that car had a three barrel on it. That's the first time I'd ever heard of such a thing.
Re: Avs three barrel mod [Re: burdar] #1530081
11/08/13 03:45 PM
11/08/13 03:45 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I remember Holley having a 3 bbl carb back in the 70s..
I am truckless..
Re: Avs three barrel mod [Re: 340SHORTY] #1530082
11/08/13 04:40 PM
11/08/13 04:40 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Same here. I Have had a couple Holley 3 barreles, but I have never even heard of a Carter 3 bbl.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Avs three barrel mod [Re: Hemi_Joel] #1530083
11/08/13 05:03 PM
11/08/13 05:03 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Think he is looking at the air door.
Re: Avs three barrel mod [Re: MoparforLife] #1530084
11/08/13 05:52 PM
11/08/13 05:52 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Nope,three-barrel 3636s used on the Pontiac NASCAR 421 super duty engines.
Re: Avs three barrel mod [Re: 62maxwgn] #1530085
11/08/13 05:54 PM
11/08/13 05:54 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Top.
Re: Avs three barrel mod [Re: 62maxwgn] #1530086
11/08/13 05:56 PM
11/08/13 05:56 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
And that is a VERY rare carburetor!
Re: Avs three barrel mod [Re: 62maxwgn] #1530087
11/08/13 06:01 PM
11/08/13 06:01 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
cool! i bet that would be a fun little gadget.
Re: Avs three barrel mod [Re: 62maxwgn] #1530088
11/08/13 06:15 PM
11/08/13 06:15 PM
Lavonia, GA
cjbill Offline
cjbill  Offline
Lavonia, GA
Never could understand why that didn't "catch on" but instead the 4500 series came about...
Looks like it would be great for a hot 440, although all the ones I've seen (Holleys) have no choke.
ex-Ford guy, but Mopars nowadays
Re: Avs three barrel mod [Re: lewtot184] #1530089
11/08/13 06:18 PM
11/08/13 06:18 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Wow I have been around muscle cars since the late 60's and have never heard of the Carter 3 barrel only the Holley 3 barrel. Learn something every day. Ron
Re: Avs three barrel mod [Re: 383man] #1530090
11/08/13 06:33 PM
11/08/13 06:33 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Look at the new Demon Thermo-Quad, they use a similar setup, they call the single butterfly a "goggle" valve because it's shaped like a pair of goggles
Re: Avs three barrel mod [Re: ScottSmith_Harms] #1530091
11/08/13 07:24 PM
11/08/13 07:24 PM
Texas
Texas
Looks like it would be cool to do an AVS for FAST. Or two AFB/ eddys for a big inch NSS. Wonder if a four barrel could modified and made to work.
Re: Avs three barrel mod [Re: dannysbee] #1530092
11/08/13 07:49 PM
11/08/13 07:49 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Might just give it a shot,what I don't have I can probably make,nothing to lose.
Re: Avs three barrel mod [Re: 62maxwgn] #1530093
11/08/13 08:02 PM
11/08/13 08:02 PM
Texas
Texas
I figured if anyone could make it work it would be you Bill. The originals were 1 to 1 on the linkage. Both ends opened at the same. Might be ok on a nascar but I believe progressive would be better. The avs would be easier as there would be no air valve to deal with. Keep us posted on how you are coming.
Re: Avs three barrel mod [Re: dannysbee] #1530094
11/08/13 09:15 PM
11/08/13 09:15 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Those old LD 340 intakes and others of the time had the little notch in the divider for these carbs I think
Re: Avs three barrel mod [Re: 62maxwgn] #1530095
11/09/13 10:06 AM
11/09/13 10:06 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
So, is it an AVS or AFB? it looks like it uses the full circular Venturi, unlike the Holley. how does it transition from the two Venturi to the single throttle bore?
that is very very cool.
Re: Avs three barrel mod [Re: 62maxwgn] #1530096
11/09/13 11:18 AM
11/09/13 11:18 AM
North Seattle, Washington. USA
U code RR Offline
U code RR  Offline
Very interesting carb. Do you have a pic of the top of the carb? Was it an AFB or an AVS? The top pic that is posted is a different carb from the bottom pic. Mounting holes are different.
When seconds count... The Police are only minutes away. Smith and Wesson are your friends.
