Avs three barrel mod
#1530077
11/08/13 12:47 PM
11/08/13 12:47 PM
Posts: 5,160 Texas
dannysbee
Texas
I was reading an old carter tuning guide that I have and it showed pictures of an old nascar afb that was a three barrel. Said they were quite rare. Wonder if any one had modified a four barrel afb or avs to 3 barrel for fast.
Getting old just means you were smarter than some and luckier than others.
Re: Avs three barrel mod
[Re: dannysbee]
#1530078
11/08/13 02:17 PM
11/08/13 02:17 PM
Posts: 5,160 Texas
dannysbee
Texas
It was rated over 900 cfm
[Re: burdar]
#1530081
11/08/13 03:45 PM
11/08/13 03:45 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
I remember Holley having a 3 bbl carb back in the 70s..
I am truckless..
[Re: 340SHORTY]
#1530082
11/08/13 04:40 PM
11/08/13 04:40 PM
Posts: 7,494 Minnesota
Hemi_Joel
Minnesota
Same here. I Have had a couple Holley 3 barreles, but I have never even heard of a Carter 3 bbl.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: 62maxwgn]
#1530087
11/08/13 06:01 PM
11/08/13 06:01 PM
Posts: 3,916 usa
lewtot184
usa
Nope,three-barrel 3636s used on the Pontiac NASCAR 421 super duty engines.
cool! i bet that would be a fun little gadget.
[Re: 62maxwgn]
#1530088
11/08/13 06:15 PM
11/08/13 06:15 PM
Posts: 85 Lavonia, GA
cjbill
Lavonia, GA
Never could understand why that didn't "catch on" but instead the 4500 series came about... Looks like it would be great for a hot 440, although all the ones I've seen (Holleys) have no choke.
ex-Ford guy, but Mopars nowadays
[Re: ScottSmith_Harms]
#1530091
11/08/13 07:24 PM
11/08/13 07:24 PM
Posts: 5,160 Texas
dannysbee
Texas
Looks like it would be cool to do an AVS for FAST. Or two AFB/ eddys for a big inch NSS. Wonder if a four barrel could modified and made to work.
[Re: dannysbee]
#1530092
11/08/13 07:49 PM
11/08/13 07:49 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Might just give it a shot,what I don't have I can probably make,nothing to lose.
[Re: 62maxwgn]
#1530093
11/08/13 08:02 PM
11/08/13 08:02 PM
Posts: 5,160 Texas
dannysbee
Texas
I figured if anyone could make it work it would be you Bill. The originals were 1 to 1 on the linkage. Both ends opened at the same. Might be ok on a nascar but I believe progressive would be better. The avs would be easier as there would be no air valve to deal with. Keep us posted on how you are coming.
[Re: 62maxwgn]
#1530096
11/09/13 11:18 AM
11/09/13 11:18 AM
Posts: 120 North Seattle, Washington. USA
U code RR
Very interesting carb. Do you have a pic of the top of the carb? Was it an AFB or an AVS? The top pic that is posted is a different carb from the bottom pic. Mounting holes are different.
When seconds count...
The Police are only minutes away.
Smith and Wesson are your friends.
