"Correct" 67 Barracuda front suspension colors #1529697
11/07/13 09:17 AM
11/07/13 09:17 AM
mopar346 Offline OP
Let me tell ya about fat chicks!
mopar346  Offline OP
The car in question:
67 Barracuda convertible 273 Commando/904/7.25 NON-Formula S car.
I am rebuilding the front end for a friend and I am blasting and painting tonight. I would like it to resemble correct. I just cant bring myself to paint it all black regardless of the car or situation. That is unless it was all black.
Thanks in advance, Kevin
Careful, your character's showing!
Re: "Correct" 67 Barracuda front suspension colors [Re: mopar346] #1529698
11/08/13 09:30 AM
11/08/13 09:30 AM
mopar346 Offline OP
mopar346  Offline OP
Nobody has any info???
Here is what I have come up with so far, maybe someone can tell me where I am wrong.
Draglink semi gloss black (dipped)
Tie rod ends natural cast
tie rod sleeves semi gloss black (cant tell dipped or not)
pitman arm natural cast
idler arm natural cast
Spindle natural cast
lower ball joint natural cast
strut rod natural steel
strut rod washers natural steel
lower control arm natural steel and cast cosmoline dipped within a few inches of the ball joint
upper control arm information tells me/suggest semi gloss black but when cleaning and soda blasting I was no evidence of paint
backing plate drum black phosphate
backing plate disc semi gloss black
caliper natural cast
drum/disc natural cast
tortion bars semi gloss (dipped)
sway bar semi gloss
sway bar backets semi gloss
sway bar links unsure
K member semi gloss
gear box natural cast/aluminum
what did I miss?
Re: "Correct" 67 Barracuda front suspension colors [Re: mopar346] #1529699
11/08/13 09:42 AM
11/08/13 09:42 AM
mopar346 Offline OP
mopar346  Offline OP
The only reference pictures I have: 1
Re: "Correct" 67 Barracuda front suspension colors [Re: mopar346] #1529700
11/08/13 09:44 AM
11/08/13 09:44 AM
mopar346 Offline OP
mopar346  Offline OP
A friend of mine's 67 383 Formula S
Re: "Correct" 67 Barracuda front suspension colors [Re: mopar346] #1529701
11/08/13 10:33 AM
11/08/13 10:33 AM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Center link - natural - no paint.
Sleeves and clamps/bolts are usually zinc phosphate plated - never painted. Sometimes the sleeves are bare natural.
strut rod washers natural steel - They are plated...usually silver cad...sometimes an olive plating.
I have seen some black - but the great majority are natural....with and without cosmoline
backing plate drum black phosphate (zinc phosphate)
backing plate disc semi gloss black ??
tortion bars semi gloss (dipped) They were original full black
sway bar semi gloss
K member semi gloss
what did I miss?
First - I don't have a '67 but I would imagine 69-71 stuff used basically the same approach. I have added some remarks on the ones that I think are different than what you posted.
Re: "Correct" 67 Barracuda front suspension colors [Re: FJ5_Fish] #1529702
11/08/13 10:47 AM
11/08/13 10:47 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Are you talking about the disc brake dust shields? I've got some off of a 72 that don't look painted.
Re: "Correct" 67 Barracuda front suspension colors [Re: burdar] #1529703
11/08/13 11:05 AM
11/08/13 11:05 AM
mopar346 Offline OP
mopar346  Offline OP
Thank you Fish, the more info the better, hopefully it will help someone else in the future. I could see most 67-69 As being the same but I would wonder about 70 and up Es. Although I will say that most of what I have found is consistent with my AAR. I have also seen but didn't add that the backing plates on the front can be what I believe is oliver as well.
Burdar, you are correct, I am talking about the dust sheild. You are also correct on that some in the 70s were galvanized and some were painted.
Re: "Correct" 67 Barracuda front suspension colors [Re: mopar346] #1529704
11/13/13 03:30 AM
11/13/13 03:30 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
