Steering Gear Bolts #1529569
11/06/13 09:17 PM
11/06/13 09:17 PM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
I am trying to figure out which bolts go to my steering gear box. I had everything nicely packed and marked except for those. Are they the standard hex or 12pt? My car is a 70 'Cuda 440-6. Also what size and length, thanks in advance for the help!!
Admiration For Multiple Carburetor Vehicles...
Re: Steering Gear Bolts [Re: Stewpar] #1529570
11/06/13 09:21 PM
11/06/13 09:21 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
I've seen both head types on both manual and power steering boxes, always with big lock washers, about 1 1/2 inches long.
Re: Steering Gear Bolts [Re: Stewpar] #1529571
11/06/13 09:30 PM
11/06/13 09:30 PM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
Manual steering in this case if it makes a difference. I don't have any 8pt bolts, but have seen them on past cars as well so that's why I asked..............
Re: Steering Gear Bolts [Re: Stewpar] #1529572
11/06/13 10:13 PM
11/06/13 10:13 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
IIRC they're 10 pt head bolts, that's all I've seen on manual or PS on B/E's....there's a set on Ebay for $18 right now?
mike
Re: Steering Gear Bolts [Re: DAYCLONA] #1529573
11/06/13 11:24 PM
11/06/13 11:24 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
Actually they are 12 pt so that a typical 12 pt socket will fit the bolt head
Re: Steering Gear Bolts [Re: 446acuda] #1529574
11/07/13 07:08 AM
11/07/13 07:08 AM
Ky
jt4406 Offline
jt4406  Offline
Ky
The ones in the pic above were what was on my car, (had power steering though)
Jess
Yeah, it's hopped up to over 160...
Re: Steering Gear Bolts [Re: jt4406] #1529575
11/07/13 10:48 AM
11/07/13 10:48 AM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..and they are famous for coming loose.
..torque correctly.
Re: Steering Gear Bolts [Re: Stewpar] #1529576
11/07/13 11:31 AM
11/07/13 11:31 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Here is my 71 Road Runner bolts. Its power steering. Maybe it has to do whit which plant the car was built in.
Re: Steering Gear Bolts [Re: 71birdJ68] #1529577
11/07/13 11:40 AM
11/07/13 11:40 AM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Going from my semi-good memory - I think that's what I have (the hex bolts) on my T/A's and AAR's as well....gotta look.
Re: Steering Gear Bolts [Re: Stewpar] #1529578
11/07/13 11:59 AM
11/07/13 11:59 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Mine were 6 point hex head bolts also for my 71 with power steering.
Re: Steering Gear Bolts [Re: Challenger 1] #1529579
11/08/13 05:03 PM
11/08/13 05:03 PM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
What's the length?
Re: Steering Gear Bolts [Re: Stewpar] #1529580
11/08/13 06:55 PM
11/08/13 06:55 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
Never seen a 8 pt. or 10 pt. bolt on a car. As a matter of fact, I've never seen a 10 pt. bolt anywhere.
Re: Steering Gear Bolts [Re: Stewpar] #1529581
11/08/13 07:24 PM
11/08/13 07:24 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Hex...(On my manual box)...
Use loc-tite...
Re: Steering Gear Bolts [Re: RSNOMO] #1529582
11/08/13 08:53 PM
11/08/13 08:53 PM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
I think I have them, what's the length???????
Re: Steering Gear Bolts [Re: Stewpar] #1529583
11/08/13 09:45 PM
11/08/13 09:45 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
a
I am not home to measure. I think they are around 3.5 - 4.0 inches long. The hex head is 0.75 - 1.0 inch thick.
Uses a 3/4 inch socket.
Re: Steering Gear Bolts [Re: cudaized] #1529584
11/08/13 09:46 PM
11/08/13 09:46 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
b
Re: Steering Gear Bolts [Re: cudaized] #1529585
11/08/13 10:20 PM
11/08/13 10:20 PM
california
Mr D21 Offline
Mr D21  Offline
california
1970 Chall - LA built
Re: Steering Gear Bolts [Re: Mr D21] #1529586
11/08/13 11:18 PM
11/08/13 11:18 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
mine too exactly, two shims between the box and frame under the top two bolts, 5/70 LA built car
jess
Re: Steering Gear Bolts [Re: jt4406] #1529587
11/09/13 11:04 AM
11/09/13 11:04 AM
california
Mr D21 Offline
Mr D21  Offline
california
interesting - I thought a shim might be missing,,,
Re: Steering Gear Bolts [Re: Mr D21] #1529588
11/09/13 11:21 AM
11/09/13 11:21 AM
Ky
jt4406 Offline
jt4406  Offline
Ky
I have read many threads on this website about the difference in E body and B body k-members, and one concern seemed to center around the differences in the angle the steering columns entered the steering box from the different body styles. I wonder if the shims are there to correct the difference? I thought the e body platform may require a lower angle on the column whick they made up for by shimming the top of the box toward the firewall... .....entirely speculation on my part.
jess
