Why so few codes on '69 Lynch Road fender tags? #1529413
11/06/13 12:56 PM
11/06/13 12:56 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Re: Why so few codes on '69 Lynch Road fender tags? [Re: A12] #1529414
11/06/13 03:05 PM
11/06/13 03:05 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
So there's plenty of room for people to have added options stamped on them and still be able to claim it's the original tag.
As you see, I don't know either but have wondered the same.
Re: Why so few codes on '69 Lynch Road fender tags? [Re: A12] #1529415
11/06/13 03:13 PM
11/06/13 03:13 PM
CO
Redbird Online sad
Redbird  Online Sad
CO
It seems to me that fender tags were not made with the thought of making things special for collectors 40 years in the future, but rather to make things easier for the plant and to track cars easier.
Plenty of car makes for decades had such thing as a fender tag and got along just fine.
Re: Why so few codes on '69 Lynch Road fender tags? [Re: B5 Bee] #1529416
11/06/13 03:16 PM
11/06/13 03:16 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Here's my guess: to me it seems the only codes that are on the METAL Lynch Road fender tags are codes needed by Body-In-White (BIW) and the paint department or in other words only the codes that if they were on a PAPER broadcast sheet could possibly be burned from the welding and spot welding or covered with paint and couldn't be read during the assembly process.
What codes are on a Lynch Road (LR) fender tag that are not needed during BIW and paint?
Re: Why so few codes on '69 Lynch Road fender tags? [Re: A12] #1529417
11/06/13 06:44 PM
11/06/13 06:44 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
The way understand it, each dept gets a copy of the BS, so if the body shop BS was burnt or painted, the other depts have one.
Usually the sheets left in the cars were the ones from the interior dept, most others were thrown away.
Re: Why so few codes on '69 Lynch Road fender tags? [Re: B5 Bee] #1529418
11/06/13 07:07 PM
11/06/13 07:07 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Anything on here that doesn't have something to do with BIW or paint
Re: Why so few codes on '69 Lynch Road fender tags? [Re: A12] #1529419
11/06/13 07:08 PM
11/06/13 07:08 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
I have read that before and it makes sense. The one thing I find odd, is that you would think the radio code would be on the LR tag, but it isn't. I would assume the "body in white" guys would need to know if they should knock a hole in the fender or not for the antenna...
Re: Why so few codes on '69 Lynch Road fender tags? [Re: B5 Bee] #1529420
11/06/13 07:10 PM
11/06/13 07:10 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
But if it burned up right at the first weld how would the kept track of what it is or what it gets before it even moved in the gate?
Re: Why so few codes on '69 Lynch Road fender tags? [Re: A12] #1529421
11/07/13 12:11 AM
11/07/13 12:11 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
When you compare what was and wasn't coded, you have to ask why was LR different than other plants. Why was it OK for some plants to codes those items you covered earlier but not LR? One would think your concerns about the welding were ignored at other plants.
The picture you posted and the items it contains are pretty much the same info you find at other plants. The major exception is the top row of gate/base/sequence. Other than that, you'll find the same codes on other tags PLUS additional sales codes.
Would P31 be related to BIW? That code does show up on 69 LR tags.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: Why so few codes on '69 Lynch Road fender tags? [Re: 69CoronetRT] #1529422
11/07/13 01:07 AM
11/07/13 01:07 AM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
What would they need to do in BIW to the door to install P31-power windows?
Re: Why so few codes on '69 Lynch Road fender tags? [Re: 69CoronetRT] #1529423
11/07/13 01:26 AM
11/07/13 01:26 AM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Doug this is all just a guess on my part and we know that Lynch Road did a few other things that were not done the same in the other plants like the hanging of the fender tag and not one screw holding to the inner fender until after paint. So it seems (to me ) that 95% of the codes on the LR fender tag were items that, again to me at least, were codes that could pertain to BIW or paint items.
This is a hobby to me and supposed to be fun
(still trying to locate a NOS Lynch Road fender tag paper clip )
Re: Why so few codes on '69 Lynch Road fender tags? [Re: A12] #1529424
11/07/13 01:50 AM
11/07/13 01:50 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Got me. Of all the codes that do show up, that one is perplexing. I think it's pretty odd considering the ones that would affect BIW they didn't code. (radio, Tach, fender turn signals, etc, etc,)
Seeking:
Re: Why so few codes on '69 Lynch Road fender tags? [Re: 69CoronetRT] #1529425
11/07/13 02:30 AM
11/07/13 02:30 AM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
P31 power windows requires a large hole in the door pillar for the wiring, door also needs a hole, holes are punched not drilled
Same reason tach, a/c or air grabber is on tag, they all need special holes before paint
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: Why so few codes on '69 Lynch Road fender tags? [Re: AZ_A12_BEE] #1529426
11/07/13 12:17 PM
11/07/13 12:17 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Dave do you have any photos of the larger door holes for power windows?
Re: Why so few codes on '69 Lynch Road fender tags? [Re: AZ_A12_BEE] #1529427
11/07/13 10:08 PM
11/07/13 10:08 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Which is why I find it odd that a tach, radio or fender turn signals are not coded. They would certainly be much more common than PW. How did PW make the cut and not the other three?
Seeking:
Re: Why so few codes on '69 Lynch Road fender tags? [Re: A12] #1529428
11/07/13 11:34 PM
11/07/13 11:34 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
I can tomorrow, I just happen to have a power window convertible at my shop
