Intake manifold to head spacers #1529079
11/05/13 06:57 PM
11/05/13 06:57 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Got about 1/8" gap on both sides ( measured without any gaskets in place ) between my Victor 340 and aluminum Edelbrock heads using .051" MLS head gaskets. Does anyone make spacers ( or extra thick gaskets)for stock configuration ports? Going to a thinner head gasket will create quench clearance issues. Thanks, John
Fastest 300
Re: Intake manifold to head spacers [Re: Crizila] #1529080
11/05/13 07:32 PM
11/05/13 07:32 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Far as I've seen you'll need to double up on a pair of .062" gaskets and end up with .124"
The ones I offer are silicone beaded and will add .008" to the .062" (.070") x 2 = .140"
Hope this helps
Re: Intake manifold to head spacers [Re: roadhazard] #1529081
11/05/13 08:35 PM
11/05/13 08:35 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Hope this helps
Thanks Greg. Might have to go that route. I'd rather go with a spacer since I am running a blown application, but - - - don't know anyone that makes them.
Fastest 300
Re: Intake manifold to head spacers [Re: Crizila] #1529082
11/05/13 08:36 PM
11/05/13 08:36 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
nuther pic.
Fastest 300
Re: Intake manifold to head spacers [Re: Crizila] #1529083
11/05/13 09:11 PM
11/05/13 09:11 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Could copy a gasket onto a 1/16" aluminum plate. It would cut & smooth pretty quick.
Re: Intake manifold to head spacers [Re: 80fbody] #1529084
11/05/13 10:27 PM
11/05/13 10:27 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Leaning in that direction
Fastest 300
Re: Intake manifold to head spacers [Re: Crizila] #1529085
11/05/13 11:27 PM
11/05/13 11:27 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
i can cnc a set for you. just let me know what thickness you need.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Intake manifold to head spacers [Re: Crizila] #1529086
11/06/13 10:34 AM
11/06/13 10:34 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
So you have an 1/8" (.125") gap. You will still need two gaskets, one on each side of the plate, no?
In my estimation your gap .125" - .062" gasket leaves .063" and the thinnest material I offer for the other side is .015" leaves you with a .048" thick plate.
Does not seem worth the effort to me but it's your motor.
I had a brain fart and had my machinist mill the intake side of my heads at the wrong angle. I made a plate and have a .031" gasket on one side and .031" on the other between the plate and head.
At one time I had used a combination of .062" and .015" gaskets.
Re: Intake manifold to head spacers [Re: roadhazard] #1529087
11/06/13 11:53 AM
11/06/13 11:53 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We just had the same issue and we did what Greg recommended.We glued two gaskets together for each side and solved the problem,quick and easy.Chrysler and MR Gasket used to make gaskets extra thick,.090,and .125.We like the quality gaskets that Greg makes and we have done the same on Hemis and wedges.We have glued .030 and .060 to get .090 and .060 and .060 to get .125 gaskets.The thick gaskets from Chrysler and Mr Gasket look like multiple gaskets laminated together also.
Re: Intake manifold to head spacers [Re: B G Racing] #1529088
11/06/13 12:19 PM
11/06/13 12:19 PM
NJ
JCCuda Offline
JCCuda  Offline
NJ
Who makes an .030 gasket for a standard port small block?
Re: Intake manifold to head spacers [Re: B G Racing] #1529089
11/06/13 12:30 PM
11/06/13 12:30 PM
ohio
all spooled up Offline
ohio
he has a blow thru blower building boost does not what to blow the thick gasket out
Re: Intake manifold to head spacers [Re: all spooled up] #1529090
11/06/13 12:57 PM
11/06/13 12:57 PM
Guitar Jones Offline
I had to do the same thing with my W5's. I don't think the blower would blow the gasket out once it's properly clamped. If it does it would blow a single gasket out as well.
Re: Intake manifold to head spacers [Re: roadhazard] #1529091
11/06/13 01:17 PM
11/06/13 01:17 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Actually lined things up this morning and I have a 3/16" gap ( .1875" ) on each side. That is a lot to fill with gaskets ( probably need 3 per side ). Yes, I could probably get away with gluing stuff together, but the boost issue bothers me. Putting 20 lbs. of pressure in to the crankcase at speed would not be a pretty thing. If I sandwiched a 1/16" aluminum spacer between two .062" gaskets, that would get me there.??
Fastest 300
Re: Intake manifold to head spacers [Re: Guitar Jones] #1529092
11/06/13 01:19 PM
11/06/13 01:19 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We use thick gaskets on our Blown alcohol hemi with a 14-71 blower.The pressure should go to the cylinders not build up in the intake.With proper clamping and occasional retorquing it should be the same as any gasket.I wouldn't recommend it in situations requiring more than .125+-.Using a thin plate and two thin gaskets can be an issue also.We see the thin metal valley gaskets with two thin gaskets that are used on some big blocks leak and have to have globs of silicone and other sealers to seal.
Re: Intake manifold to head spacers [Re: B G Racing] #1529093
11/06/13 01:25 PM
11/06/13 01:25 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
I was also thinking of going with a 1/8" spacer and gluing it directly to the manifold ( no gasket ) and then going with one .062" gasket between the spacer plate and the head??
Fastest 300
Re: Intake manifold to head spacers [Re: Crizila] #1529094
11/06/13 01:28 PM
11/06/13 01:28 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
How well do the ports line up? Could you possibly oblong the bolt holes to lower the manifold & gasket match it? Maybe you can get it a little closer so two gaskets would work.
Re: Intake manifold to head spacers [Re: Crizila] #1529095
11/06/13 01:33 PM
11/06/13 01:33 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Just one of many different ways to solve an issue Greg's suggestion was the quick,easy and cheap or KISS method.Your suggestion is viable if you have access to machinery to preciesly make a spacer.I would try the KISS approach first.
Re: Intake manifold to head spacers [Re: B G Racing] #1529096
11/27/13 06:21 PM
11/27/13 06:21 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Here is the set of 1/8" thick manifold spacers "Jerry" on this web sight / thread machined for me. Along with a set of .060" gaskets, they fit perfect.
Fastest 300
Re: Intake manifold to head spacers [Re: Crizila] #1529097
11/27/13 06:22 PM
11/27/13 06:22 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
pic2
Fastest 300
Re: Intake manifold to head spacers [Re: Crizila] #1529098
11/27/13 06:23 PM
11/27/13 06:23 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
pic3 = 3/32" locating spring pins on all 4 corners.
Fastest 300
