CHALLENGER PLASTIC FRONT LOWER VALENCE INSERT, 3573495? #1528237
11/03/13 06:44 PM
11/03/13 06:44 PM
Fairfield, Ohio
holtzdog55 Offline OP
Fairfield, Ohio
Anybody have any pics of this front lower valence insert mounted to a challenger?? How is it mounted? any help appreciated.....
Finally Done....BEERS!!!
Re: CHALLENGER PLASTIC FRONT LOWER VALENCE INSERT, 3573495? [Re: holtzdog55] #1528238
11/03/13 06:46 PM
11/03/13 06:46 PM
Fairfield, Ohio
Fairfield, Ohio
I know right side is broken with small piece missing......this is up for grabs by the way....I have one that is fully intact for my car.......
Re: CHALLENGER PLASTIC FRONT LOWER VALENCE INSERT, 3573495? [Re: holtzdog55] #1528239
11/04/13 12:50 PM
11/04/13 12:50 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Photobucket is down right now. When it comes back up I'll post a picture. Remember to paint the lip silver. I see a lot of cars missing that silver lip.
Re: CHALLENGER PLASTIC FRONT LOWER VALENCE INSERT, 3573495? [Re: burdar] #1528240
11/04/13 12:55 PM
11/04/13 12:55 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Re: CHALLENGER PLASTIC FRONT LOWER VALENCE INSERT, 3573495? [Re: burdar] #1528241
11/04/13 01:06 PM
11/04/13 01:06 PM
Fairfield, Ohio
Fairfield, Ohio
OK, so it goes on before the grill goes on......Thanks, great pics......
Re: CHALLENGER PLASTIC FRONT LOWER VALENCE INSERT, 3573495? [Re: holtzdog55] #1528242
11/04/13 01:32 PM
11/04/13 01:32 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
It mounts in the valence. It has nothing to do with the grill.
Put the aluminum trim on the valence first. Then install the plastic piece. You'll want to install the valence after the bumper is installed. I just had it attached to the car to keep it safe and out of the way.
Re: CHALLENGER PLASTIC FRONT LOWER VALENCE INSERT, 3573495? [Re: holtzdog55] #1528243
11/04/13 03:36 PM
11/04/13 03:36 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
I had a damaged one on my 73. I removed it and replaced it with a good one. You can do it with everything intact on the frontend: header, grill, bumper, valance. It comes off quite easily...
Re: CHALLENGER PLASTIC FRONT LOWER VALENCE INSERT, 3573495? [Re: 318 Stroker] #1528244
11/04/13 05:31 PM
11/04/13 05:31 PM
Fairfield, Ohio
Fairfield, Ohio
Do you happen to have a picture of it actually mounted when everything is there??
Or pics of it on the valance and what hardware is used to attach it.......
My car never had one....just saw a pic one time and liked the look.....so pardon the stupidity......lol
Re: CHALLENGER PLASTIC FRONT LOWER VALENCE INSERT, 3573495? [Re: holtzdog55] #1528245
11/04/13 06:20 PM
11/04/13 06:20 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
There are those stamped steel nuts that push onto the valence tabs. The bolts are very small with a captive washer. I think they are very similar to the four fasteners that hold the dash in at the base of the windshield...except they are black phosphate. They might say SEM on the head. I may have an extra bolt at home I can look at.
With the bumper and license plate bracket installed, it's not that visible unless you really look for it.
