lil disappointed
#1528171
11/03/13 06:07 PM
11/03/13 06:07 PM
Posts: 1,285 okla.
sam64
okla.
took my 65 coronet to Tulsa yesterday in hopes of a 9 sec pass,but 10.19@132.5 was all I got.512 lowdeck,cleaned up sr's,solid flat tappet cam .611-.620,268-272,single plane m1,1050 dom 90 square,3800 conv 727,4.30 31.5x10.5wx15 m/t,back half ladder bars.weighs 2990 race ready.1.52 60ft,4.24 330,6.517 1/8 107.37,10.194 132.49.me thinks need more stall,at about 100ft out I feels like you hit the nitrous button.i shifted it a 7,000.
Re: lil disappointed
[Re: sam64]
#1528172
11/03/13 06:20 PM
11/03/13 06:20 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
Definitely needs more converter, good work none the less!
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: sam64]
#1528173
11/03/13 06:20 PM
11/03/13 06:20 PM
Posts: 1,770 Pa
Wv68charger
Pa
took my 65 coronet to Tulsa yesterday in hopes of a 9 sec pass,but [Email]10.19@132.5[/Email] was all I got.512 lowdeck,cleaned up sr's,solid flat tappet cam .611-.620,268-272,single plane m1,1050 dom 90 square,3800 conv 727,4.30 31.5x10.5wx15 m/t,back half ladder bars.weighs 2990 race ready.1.52 60ft,4.24 330,6.517 1/8 107.37,10.194 132.49.me thinks need more stall,at about 100ft out I feels like you hit the nitrous button.i shifted it a 7,000.
None the less BEAUTIFUL CAR! And those times are nothing to sneeze at!
[Re: 67mprfan]
#1528176
11/03/13 06:46 PM
11/03/13 06:46 PM
Posts: 5,160 Texas
dannysbee
Texas
60' should be around 1.39. If traction good and your 60' is consistent the converter is where I would go. Have you done any experimenting with your shift points? I would think that a 6500 shift point would get you down the track quicker.
Getting old just means you were smarter than some and luckier than others.
[Re: dannysbee]
#1528177
11/03/13 07:14 PM
11/03/13 07:14 PM
Posts: 1,285 okla.
sam64
okla.
only 6 passes with this engine combo,i can't feel it spin 60's all 1.51-52,but when it gets out 100ft it comes alive,at 6500 shifts it went 10.40.
[Re: 1967Valiant]
#1528178
11/03/13 07:18 PM
11/03/13 07:18 PM
Posts: 1,285 okla.
sam64
okla.
4500 converter 4.10 gear
I have 14.5x32x15 m/t that would equal changing gears that I can try.
[Re: CHAPPER]
#1528180
11/03/13 07:25 PM
11/03/13 07:25 PM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
i agree with most--- 4500 or so stall , and shift it lower = try 6500 . my 493 likes just under 6k !
is that the Hughes cam ??? i have that same one
[Re: 493_DART]
#1528181
11/03/13 07:29 PM
11/03/13 07:29 PM
Posts: 1,285 okla.
sam64
okla.
yes it's hughes cam and their 1.5 rockers.
[Re: Eric]
#1528184
11/03/13 08:27 PM
11/03/13 08:27 PM
KOS
Maybe it's just me but I would be looking more at 5000-5200 on the converter...
[Re: KOS]
#1528186
11/03/13 08:46 PM
11/03/13 08:46 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I agree also, 5000+ custom built converter for your combo, keep your 4.30's, need to get that 60 foot down and the rest of the ET will come down with it. Nice car and it runs good, you will easily hit 9's as you've only made 6 passes so far.
[Re: sam64]
#1528190
11/03/13 10:04 PM
11/03/13 10:04 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
like hemiits asked,what is your timing curve and and like Cab said to much fuel at the hit will make it lazy especially if your timing is coming in slow
my old combo with a solid cam and 4000 converter would 60 in the 1.4s at 3700lbs. a 315 drag radial would be faster
I use to shift my standard port solid cam combo at 5800 and it ran 6.70s a lot heavier than you. your converter is fine. ports are to small
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
