1971 big block 22" E body radiator question #152746
11/17/08 11:36 PM
11/17/08 11:36 PM
N.E. Ohio
K
KillerBee Offline OP
K
N.E. Ohio
My 1971 R/T Challenger originally came with a 22" radiator (383 4 speed, non air).
Unfortunately my car's original radiator is long gone.
I understand finding an original 1971 B/E body big block, 22", manual tranny radiator is difficult and expensive.
I'm looking at aftermarket repops but I'm confused as to the radiator's correct outlet locations.
From the repop radiator websites they're showing the upper and lower radiator outlets are both on the left(driver's) side for my big block 22" application. (Kinda looks like a small block application).
Shouldn't the upper radiator outlet be on the right(passenger) side?
Anyone know of a company that sells a fairly original looking(not universal) and affordable 22" radiator (aluminum is OK) with the correct mounting brackets installed?
Thanks.
Re: 1971 big block 22" E body radiator question [Re: KillerBee] #152747
11/18/08 11:24 AM
11/18/08 11:24 AM
Wausau Wisconsin USA North Ame...
radiatorman Offline
radiatorman  Offline
Yes they both are on the drivers side of the car. When you had the 26" one it was on the passenger side. I have a restored/recored 2998954 radiator if your interested. It has a 3-row core in it. I guess it also depends on if your restoring your car or if its just going to be a nice driver. If you go with a aftermarket one remember, cheap doesn't get you quality. And when it gives you problems, good luck getting your cash back.
Bob Schirmer
Glen-ray Radiators
1.800.537.3775
1.715.842.3352
Re: 1971 big block 22" E body radiator question [Re: KillerBee] #152748
11/18/08 12:24 PM
11/18/08 12:24 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
There was someone posting a WIW 22" big-block radiator on here not too long ago.
Re: 1971 big block 22" E body radiator question [Re: KillerBee] #152749
11/18/08 02:27 PM
11/18/08 02:27 PM
The Dark Side
Fasbird Offline
Fasbird  Offline
The Dark Side
KillerBee,
Tried to send you a PM but your box is full.
Gar
Re: 1971 big block 22" E body radiator question [Re: Fasbird] #152750
11/18/08 05:17 PM
11/18/08 05:17 PM
Calgary, Alberta Canada
m46rat Online content
m46rat  Online Content
Bob: He wants a 71 radiator, which would be a 3443 960.
Re: 1971 big block 22" E body radiator question [Re: Fasbird] #152751
11/18/08 06:45 PM
11/18/08 06:45 PM
N.E. Ohio
K
K
N.E. Ohio
Thanks for the info guys.
I'm not sure what direction I plan to go.
I'm installing a 440 sixpack engine in the car.
I currently have an older style round top 22" radiator that cooled a 440 engine OK in the past.
I also have a nice 26" radiator that I could install using Be Cool's 22" to 26" mounting adaptors and not have to drill extra holes in my radiator support.
It would be nice to have a correct looking 22" radiator but I'm not spending big bucks on the rare 1971 big block, manual transmission only piece since the car is not going to be an all original restoration. Possibly a 22" from another B or E body.
I cleaned out my PM box also.
Re: 1971 big block 22" E body radiator question [Re: KillerBee] #152752
11/18/08 09:59 PM
11/18/08 09:59 PM
The Dark Side
Fasbird Offline
Fasbird  Offline
The Dark Side
how about this one that came in my '71 RR. I've owned the car since '78. '71 RR 383, 4spd. car.
Re: 1971 big block 22" E body radiator question [Re: Fasbird] #152753
11/18/08 10:00 PM
11/18/08 10:00 PM
The Dark Side
Fasbird Offline
Fasbird  Offline
The Dark Side
oops. The side brkt needs to be resoldered.
Re: 1971 big block 22" E body radiator question [Re: Fasbird] #152754
11/18/08 10:01 PM
11/18/08 10:01 PM
The Dark Side
Fasbird Offline
Fasbird  Offline
The Dark Side
tank number. What does the book say. Like I said, this rad was in the car when I bought it in '78. I have had it changed to a 3-core a number of years ago.
Re: 1971 big block 22" E body radiator question [Re: Fasbird] #152755
11/19/08 02:54 PM
11/19/08 02:54 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
Get the core from Fastbird and send it to GlenRay for a re-core...It will look and work better than new when you get it back. Dont worry about the numbers, most 22in are the same, 4spd cars had the trans cooler lines pluged in the lower tanks. Give Bob at Glen Ray a call for info on this. Orig fan shrouds for 22 in were at one time hard to find but today they are everyware.
Re: 1971 big block 22" E body radiator question [Re: THESHAKERPROJECT] #152756
11/19/08 03:10 PM
11/19/08 03:10 PM
The trans. cooler lines on 22" E body rad. bottom tanks were NOT plugged. The two holes for them do no exist on standard trans. 22" rads. That is part of the reason why 22" standard trans. rads have different part numbers than automatic ones. This also applies to 19" rads too. On 26" E Body rads, the cooler lines were plugged, the bottom tanks on 26" E Body rads are the same for both automatic and four speed cars.
Re: 1971 big block 22" E body radiator question [Re: m46rat] #152757
11/19/08 06:24 PM
11/19/08 06:24 PM
NORTHERN VA
NORTHERN VA
Yeah,I was thinkin of the 26in but I still would find one from an auto car/truck and just plug the tranny cooler lines and have a good core put in to look way more correct that a aftermkt rad.
Re: 1971 big block 22" E body radiator question [Re: THESHAKERPROJECT] #152758
11/19/08 09:35 PM
11/19/08 09:35 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
There is no BB 4 speed radiator. The 4 speed portion of it is just the plugs in the tranny cooler.
The 22" radiator is determined by whether you had AC or what gears you had.
If you have no AC and 3.23 gears you got a 22" radiator. My 70 Superbee Coupe V coded 440 car has a 22" radiator and 3.23 gears.
Re: 1971 big block 22" E body radiator question [Re: m46rat] #152759
11/20/08 09:57 AM
11/20/08 09:57 AM
radiatorman Offline
radiatorman  Offline
oops... i'm bad. It is suppose to be a 3443962. I guess I should read before I type. I don't have that part #. And yes she is a spendy one if you find it. If your not worried about the part # on the top tank, I have about 20 tank sets to make something with.
Bob
Re: 1971 big block 22" E body radiator question [Re: KillerBee] #152760
11/20/08 12:42 PM
11/20/08 12:42 PM
Tecumseh, Ontario, Canada
Moparnut Offline
Moparnut  Offline
One is for sale in the ebody parts for sale area
Rare 1971 B/E body 22" radiator manual trans I have pn# 3443 962. It was in running car with no known issues up to last week. Includes the shroud with Chrysler PN on it.
I have pictures I can email.
$500 plus $50 for shipping
Mark
253-630-2004
mtdug@comcast.net
Re: 1971 big block 22" E body radiator question [Re: Moparnut] #152761
11/20/08 01:05 PM
11/20/08 01:05 PM
The Dark Side
Fasbird Offline
Fasbird  Offline
The Dark Side
KillerBee will have to chime in, but I think we have worked out a beneficial deal for him.
As an FYI, my rad does not have outlets/taps or orifices for cooler lines.
Re: 1971 big block 22" E body radiator question [Re: Fasbird] #152762
11/20/08 02:41 PM
11/20/08 02:41 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Did you ever figure out what 3736 935 was originally from?
I went through a bunch of parts catalogues (car & truck) & couldn't find that number, but I am missing some from the mid-70s.
Re: 1971 big block 22" E body radiator question [Re: 6bblgt] #152763
11/20/08 02:55 PM
11/20/08 02:55 PM
The Dark Side
Fasbird Offline
Fasbird  Offline
The Dark Side
Nope. I bought the car from the original owner in '78. This has been in the car for the entire time I have owned it. But, the numbers do not run with the rads listed. However, it's definitely a Chrysler rad with a penastar, etc. It also definitely for use with a stick, as it does not have any outlets for cooler lines.
