Dynomax VT mufflers? #1527376
11/02/13 12:08 PM
11/02/13 12:08 PM
Canada
demon Offline OP
demon  Offline OP
Canada
Anyone tried the VT mufflers. They have a valve that opens to make them straight thru when you floor it.
I am thinking about putting some on my Lil Red Express. I wonder how they would sound with the stacks.
Re: Dynomax VT mufflers? [Re: demon] #1527377
11/02/13 12:10 PM
11/02/13 12:10 PM
Quiet at idle is how they would sound. Friend has a set on his late model hemi ram and you hear nothing until it is opened up.
Re: Dynomax VT mufflers? [Re: demon] #1527378
11/02/13 04:19 PM
11/02/13 04:19 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
From everything I've read, they rattle & it is VERY annoying. Dynomax head engineer told me the rattle was fixed, but people running them say otherwise.
Moving parts inside a muffler = cool concept, bad idea.
Re: Dynomax VT mufflers? [Re: demon] #1527379
11/02/13 07:38 PM
11/02/13 07:38 PM
michigan
jrfink Offline
jrfink  Offline
michigan
I have them on a challenger with a 383 and a second car with a 340. Both have TTI exhaust. I like them. Have not experienced the rattle, but mine are later units. Was told they changed the springs to eliminate the rattle. Drone is minimal and the sound inside is nice and then louder when you step on it. Jeff
Re: Dynomax VT mufflers? [Re: jrfink] #1527380
11/02/13 08:04 PM
11/02/13 08:04 PM
Bama
BigDawg72 Offline
BigDawg72  Offline
Bama
I bought a pair of the original design. They rattled so much I thought it was something in the bottom end of my fresh engine at first. My experience was bad! I agree that moving parts in a muffler is not a good idea.
Re: Dynomax VT mufflers? [Re: BigDawg72] #1527381
11/02/13 10:42 PM
11/02/13 10:42 PM
MO, USA
Tom Hand Offline
Tom Hand  Offline
MO, USA
We have played with many sets now. In some cases, you can't hear anything rattling. It depends upon camshaft, compression and size. We have them on a 410 with 10:8 compression and a really big cam. They only slightly thump but the noise of the exhaust pinging through the headers is far worse. The way they quiet and eliminate roar and drone is far better then the little bit of noise they make at idle sometimes.
The wire mesh you see silences the closing thump but as they flap violently, the other side may clatter. Again, big cams, big engines, big compression = thump/rattle.
Not all cars work as well but in our case, they are great. On Dad's 480 cu in Pontiac, they did clank a bit but Walker recommends against the big engine, high compression, big cam set ups.
They are truly great mufflers and since they have a sound guarantee, you have nothing to lose but a bit of time and labor trying them. I say give them a shot if your engine fits the requirements.
Tom
Re: Dynomax VT mufflers? [Re: Tom Hand] #1527382
11/03/13 12:59 AM
11/03/13 12:59 AM
Glendale Az
Darryls-Demon Offline
Glendale Az
RUN FOREST RUN!
I have then on my SB Dart, they are TERRIBLE.
Re: Dynomax VT mufflers? [Re: Darryls-Demon] #1527383
11/03/13 01:21 AM
11/03/13 01:21 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
3 words Hooker Aero Chambers !!
I am truckless..
Re: Dynomax VT mufflers? [Re: 340SHORTY] #1527384
11/03/13 05:16 AM
11/03/13 05:16 AM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
was looking to get a set for my all stock 87 mustang a while back. reports of them rattling scares me. that would drive me nuts.
contacted dynomax about it and they said as long as i have a crossover pipe i should be ok.. still scared to drop the coin on them.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Dynomax VT mufflers? [Re: abodyjoe] #1527385
11/03/13 11:08 AM
11/03/13 11:08 AM
MINNESOTA
BRONZEBEE Offline
BRONZEBEE  Offline
MINNESOTA
Dad had them on his 69 road runner with a stock 383.The passenger side would rattle at an idle,thought it was a bad muffler and swapped the mufflers from side to side and the rattle was still on the passenger side.
I think it has something to do with mounting the muffler upside down
Re: Dynomax VT mufflers? [Re: demon] #1527386
11/03/13 11:42 PM
11/03/13 11:42 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
I have a pair on order for small block. If they do not work, I will go to stock mufflers. I cannot stand the drone on the Dynomax on the car now at hiway speeds. Mine could be rattling now but I could not tell.
Craig
Re: Dynomax VT mufflers? [Re: Tom Hand] #1527387
11/04/13 09:42 AM
11/04/13 09:42 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
The part number 17138
OFFSET Camaro style,
has quite a different case
due to opposing outlets
Would it also have an advantage surppressing rattle?
http://www.dynomax.com/mufflers.php?muffler=vt
