96 Dakota rear differential #1527355
11/02/13 10:13 AM
11/02/13 10:13 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
96 Dakota 318 4x4. I may need to change the yoke. Does this diff use a crush sleeve or would I be able to simply remove and replace the yoke?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: 96 Dakota rear differential [Re: cdstl] #1527356
11/02/13 11:13 AM
11/02/13 11:13 AM
PA
Z
zooom Offline
zooom  Offline
Z
PA
The 8.25 differential uses a crush sleeve to set pinion preload. If you're careful when removing the old companion flange [after checking the rotating torque of the assembly] & replacing it with a new one [companion flange/bellville washer/pinion nut] tightened to the same rotating torque as before, you should be good to go!
Re: 96 Dakota rear differential [Re: zooom] #1527357
11/02/13 04:03 PM
11/02/13 04:03 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Re: 96 Dakota rear differential [Re: cdstl] #1527358
11/03/13 12:19 PM
11/03/13 12:19 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
use your torque wrench to take off the pinion nut .....so you know the value....
Re: 96 Dakota rear differential [Re: zooom] #1527359
11/06/13 02:07 PM
11/06/13 02:07 PM
CJD AUTOMOTIVE Offline
You need to add 5 in lbs. of torque to whatever you recorded. Don't worry about the torque to remove the nut. The crush sleeve provides the bearing preload, and has to be "reloaded" to apply preload, which is why you add 5 in/lbs. of rotating torque.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: 96 Dakota rear differential [Re: savoy64] #1527360
11/07/13 08:20 AM
11/07/13 08:20 AM
Truckville, the capital of NY
85_Ram_4speed Offline
This is false as to resetting the torque going back together. The break away torque value will always be high--usually higher than what the nut is torqued at. This is why they are set up with a turning torque value---and that value vaires between new bearings and used bearings (see sevice manual for specs for the application).
Also, most torque wrenches of any real value will not be accurate in reverse. Some upper end ones do not even have a reverse lever on them (Snap on, Mac Tools). They make a different wrench for torqing in reverse--or both ways (usually a fixed non racheting head).
Outcast Dodge guy.
