The 8.25 differential uses a crush sleeve to set pinion preload. If you're careful when removing the old companion flange [after checking the rotating torque of the assembly] & replacing it with a new one [companion flange/bellville washer/pinion nut] tightened to the same rotating torque as before, you should be good to go!
