Page 3 of 3 1 2 3
Re: xr1 block nightmare [Re: scottb] #1527129
11/08/13 12:29 PM
11/08/13 12:29 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Ritter has the money to make things right with this block I just don't think he wants to spend the extra money to make it work right put it off on the who ever buys one
Sales will be minimal untill buyers feel they are getting a quality and usable product.If he wants to successfully market this block,buyers have to be confident before purchasing a unproven or untested product.We feel that if all issues can be resolved and there is a proven performance and reliability demonstrated than he will have hit a homerun and we can all benifit.I will await a response or more info from Holgar(sixpakbee)since he has an in with Kent.
Re: xr1 block nightmare [Re: B G Racing] #1527130
10/10/14 02:52 PM
10/10/14 02:52 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
The Aluminum proto type is almost in complete engine form now. Kent has been good to deal with. This block has fought us every step of the way unfortunetly, but we are determined to make an engine out of it. We can see the light at the end of the tunnel.
We have our top pro engine builder on the case. She was showing me how to degree the cam.
I can post some progress pictures later on. Thanks.
-Kenny
Re: xr1 block nightmare [Re: StrokerAspen] #1527131
10/10/14 09:27 PM
10/10/14 09:27 PM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
have you checked to see if the oil pump passage lines up with the pump mine did not. what head gasket are you going to run. pressure test both oil and water passage. make sure they dont leak. this is the biggest problems. o are yourlifter boars true and straight.every block that i know of that went to a good machine found out the lifters are in the place. kent is good to work with till you need you money back. hope you get this thing running.
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: xr1 block nightmare [Re: WHITEDART] #1527132
10/10/14 10:30 PM
10/10/14 10:30 PM
Alberta Canada
Alberta Canada
Yeah, every problem you have run into, I'm sure we have run into. We are documenting it all along with pictures. I'd personally like to see these blocks come around, and I hope that we can help the final product become a useable product for us Mopar guys. As frustrating as it has been, we just want to see these things succeed at this point. All the other hot rodders in the Brand X stuff have choices. It would be nice for Mopar guys to have choices too.
-Kenny
Re: xr1 block nightmare [Re: StrokerAspen] #1527133
10/10/14 10:36 PM
10/10/14 10:36 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I know Kent is a very smart guy, and sells lots of parts to folks.
What I don't get is how in any way shape or form he shouldn't get called out for maliciously selling a lousy block and taking people's money for it.... Fully aware it wasn't usable.
Shame on the guy....... Sorry, zero excuse for that in my opinion
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: xr1 block nightmare [Re: StrokerAspen] #1527134
10/11/14 01:54 AM
10/11/14 01:54 AM
Socal
littleVAL Offline
littleVAL  Offline
Socal
so what are the problems with the block I had thought of getting one instead of an r3 block in the future. I had hoped that in time they would sort it out.
Re: xr1 block nightmare [Re: littleVAL] #1527135
10/11/14 02:46 AM
10/11/14 02:46 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I can tell u all the problems I had with his block. I would type all the problems I found but it would be too much typing. It's a real stout piece, hope it gets straightened out for us mopar guys since r3's are scarce.
Re: xr1 block nightmare [Re: littleVAL] #1527136
12/15/14 10:27 PM
12/15/14 10:27 PM
Alberta Canada
Alberta Canada
The Aluminum Ritter block has fired on our dyno. It is not ready to go in a car yet, as there are some things we need to change on the block (oil drain back issues) but we are getting closer. I'll update as we get through it.
-Kenny
Re: xr1 block nightmare [Re: StrokerAspen] #1527137
12/15/14 11:04 PM
12/15/14 11:04 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
In all seriousness, are the issues you've tackled going to be addressed in Kent's blocks or are you kind of the last Mohican in this situation?
What's the power level you're shooting for? I wanna know the threshold of this thing?
Re: xr1 block nightmare [Re: StrokerAspen] #1527138
12/16/14 01:43 AM
12/16/14 01:43 AM
bean town ....Ca
W
W
bean town ....Ca
What head gasket are you using.I'm looking for ideas thanks.looks like to me the water passages in the deck are for p-7 head which does not work with an LA style head I'm still having a hard time getting the heads sealed upgrade
Re: xr1 block nightmare [Re: SpareParts] #1527139
12/16/14 02:50 AM
12/16/14 02:50 AM
Alberta Canada
Alberta Canada
I will stop by the shop this week and se how things look. It is a 468ci. 245CNC Indy headed deal. I think around 12:1 if I recall correctly. Sorry for the grey info, it really has been a while since Dad and I were talking about the details on this unit. It is a solid roller deal with specs around 277/284 @ .050" I think, I REALLY JUST NEED TO SIT DOWN AND MAKE A BUILD THREAD! I might find the time in the Christmas season. That should give you a sorta kinda idea of the power that is being asked from this unit. The block does look like a well built piece, just a lot of stuff that is placed bad, and not thought out very well. Thankfully we have a great machine shop that we work with, and they know how to use their equipment well to correct the problems.
As for head gaskets, I'll get you the for sure details on them. This block may be different than yours WHITEDART. I know of another iron block that is up hear and it's not useable because of a different set of problems.
I am hoping this whole deal can be sorted out to supply us Mopar dude's with a good block with availability. I got a 48 degree 9.600" siamezed R3 block about 6 months ago for a customer. I recently started as a new car salesman at a local Dodge dealer. It's our slow time so I went over to the parts guy and gave him the same part number and it comes up as discontinued. I don't know what the deal is there, I hope Mopar sorts its stuff out and starts making them again.
-Kenny
Re: xr1 block nightmare [Re: StrokerAspen] #1527140
12/16/14 04:38 AM
12/16/14 04:38 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
I finished an edelbrock headed 434 using a 59* ritter iron block early this year. Other than lack of counterweight clearance, [was clearanced by ritter for a 30 pound Winberg crank like he would use], only a few other minor issues. Engine was beat on all year with no issues. Not the most powerful engine, but not bad for eddy RPM heads. 3300 pound Dart. Car not that heavy but driver not that light. Ran 6.35 at 109 mph.
Re: xr1 block nightmare [Re: qwkmopardan] #1527141
12/16/14 08:25 AM
12/16/14 08:25 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
That's faster than my Mopar R1 59* B1BA ancient deal. Mine averages 6.55 @ 106 in average air. Rock solid, just an under achiever.
Re: xr1 block nightmare [Re: StrokerAspen] #1527142
12/16/14 11:52 AM
12/16/14 11:52 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
-Kenny
try to order any R3 number and it comes up "NS1" which means they are not making them anymore. you can't even put an order in to show demand, it just spits it back at you. they hit this status last June.
Re: xr1 block nightmare [Re: qwkmopardan] #1527143
12/16/14 12:36 PM
12/16/14 12:36 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
I have been to Accelaquarter one day in my life and I saw your car there, good runner for the combo. Didn't know it was a Ritter block
Re: xr1 block nightmare [Re: J_BODY] #1527144
12/16/14 02:03 PM
12/16/14 02:03 PM
Alberta Canada
Alberta Canada
-Kenny
Wow, we just got in there in time. That is a serious bummer though!
-Kenny
Re: xr1 block nightmare [Re: SpareParts] #1527145
12/16/14 02:55 PM
12/16/14 02:55 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Actually not my car. A good friends car. Mine is the LeBaron or white Demon depending on the day you were there. The Demon has a 418 C.I. sm block, stock block and cyl. head combo that runs very well for what it is. Also has a flat tappet cam and burns gasoline. Weighs 3050 pounds. Even with 1875 passes, it still ran low 6.2s at 109mph late this year. When engine was new and fresh it went 6.09 at 111 mph. The Lebaron is a 512 C.I. BBM, World block, Indy SR head engine with the same grind flat tappet camshaft, [Racer Brown STX-22], that's in the sm block in the Demon. It has been 5.45 at 126 mph. Weighs 2560 pounds.
Page 3 of 3 1 2 3
