acceptible cleance on a stroker 440 #1527078
11/01/13 06:56 PM
11/01/13 06:56 PM
michigan woods
imfixinmopars426 Offline OP
michigan woods
whats the good clearance on a 440 stroker from crank/rod to block.thanks,mike
Re: acceptible cleance on a stroker 440 [Re: imfixinmopars426] #1527079
11/01/13 07:23 PM
11/01/13 07:23 PM
.030" is plenty as there is no real material growth there as opposed to the piston/rod on the other end (& .040" quench works on that far end)
Re: acceptible cleance on a stroker 440 [Re: imfixinmopars426] #1527080
11/02/13 12:10 AM
11/02/13 12:10 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
In my 440/493, the only areas that needed clearancing were at the bottoms of the bores and at the oil pump/pickup boss. I went a little overboard and ended up with about 1/8" of room. Thats .125 in decimal terms.
Re: acceptible cleance on a stroker 440 [Re: Kern Dog] #1527081
11/02/13 07:31 AM
11/02/13 07:31 AM
michigan woods
michigan woods
thanks guys...finally starting to assemble one of the 496's..thanks again,mike
Re: acceptible cleance on a stroker 440 [Re: imfixinmopars426] #1527082
11/02/13 10:46 AM
11/02/13 10:46 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I used a coat hanger to check clearance ... so about 1/8".
Re: acceptible cleance on a stroker 440 [Re: RapidRobert] #1527083
11/02/13 07:31 PM
11/02/13 07:31 PM
Cab_Burge Online work
Cab_Burge  Online Work
I agree on both I make my owned crankshaft scrapers out of .030 or thcker alumimun to help reduce crankcase windage, it helps keep oil in the pan and frees up some HP above 5000 RPM. I shoot for .030 to .045 cold clearances on the rotating parts for them
