lost four wheel drive
#1526938
11/01/13 02:09 PM
11/01/13 02:09 PM
Posts: 1,180 clarks summit pa
73cuda340
clarks summit pa
I have a 85 dodge w150 that the four wheel drive stopped working all of a sudden. It worked fine when I used it last winter and the last time that I went to use it, it wouldn't go in. Being that it worked fine and then just stopped for no reason the only thing that I can think is that the vacuum actuator on the axle went bad. It has warn manual lockout hubs and I can watch the axle shafts engage and disengage when I lock the hubs and the transfer case shifts fine through all of the ranges. Is there a way to test the actuator or any other ideas?
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: lost four wheel drive
[Re: buildanother]
#1526940
11/01/13 03:39 PM
11/01/13 03:39 PM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
The vacuum switch on top of the transfer case, likes to stick. You can turn it out, and see if the ball plunger is stuck up. It usually is, from not being used. OR you may have a broken vacuum line going to the switch on top of transfer case, or going to the front axle actuator.....
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: Dartsport540]
#1526941
11/11/13 12:09 PM
11/11/13 12:09 PM
Dartsport540
Ringtown, Pa.
Just wondering if you got it fixed??
[Re: Dartsport540]
#1526942
11/11/13 02:36 PM
11/11/13 02:36 PM
Posts: 4,569 Motor City
6PKRTSE
Motor City
Yep, mine failed on me last winter. Turned out to be the large 4 port plug on top of the t-case was all dry rotted & sucking air. They are not available from the Stealership or aftermarket. I had to make a schematic as to which hose went where, eliminate the plug & install all four lines individually back onto the t-case switch. It has been working flawlessly since.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 73cuda340]
#1526945
11/12/13 02:23 PM
11/12/13 02:23 PM
Posts: 1,552 Michigan
Kiddart
I used a good citrus cleaner on the vacum switch on the T case soak it for about in hour then do some very light vac test. should take care of the problem.
Thank you Kiddart
