Internally regulated alternators - good or bad? #1526195
10/31/13 01:03 AM
10/31/13 01:03 AM
Aurora, CO
jbeintherockies Offline OP
Aurora, CO
After having my alternator (square back) bench tested at three different locations, I have accepted the fact that it needs to be replaced or rebuilt.
I was looking online to see what is available and I found some replacement alternators on summit that are internally regulated. At first thought, this sounds like a great idea. But, without a remote sensing capability, it may not always produce the desired output.
What are some things I need to consider before buying one? I have determined my existing alternator is probably a 60 amp and I don't want to go much higher than that (probably go with 75 amp alternator). If you have tried one (or not), I would like to hear your thoughts on the idea.
Re: Internally regulated alternators - good or bad? [Re: jbeintherockies] #1526196
10/31/13 03:01 AM
10/31/13 03:01 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
i just used a Toyota 4 runner alt 1989, holds 14.4v idle to 6,500rpm. you need to modify or buy a bracket. and the wiring mod is available on line somewhere .
Re: Internally regulated alternators - good or bad? [Re: ademon] #1526197
10/31/13 03:02 AM
10/31/13 03:02 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
2nd
Re: Internally regulated alternators - good or bad? [Re: ademon] #1526198
10/31/13 09:34 AM
10/31/13 09:34 AM
Columbus, GA
Michael Ecks Offline
Columbus, GA
best upgrade I ever did for my car. wiring is fairly straightforward, AR Engineering brackets are pretty cheap. No more dim headlights at idle, no more bog from low voltage I'm the ignition at take off. Stock-ish looking parts, only a die hard mopar person will notice it a car show, unlike a big chrome aftermarket piece.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Internally regulated alternators - good or bad? [Re: Michael Ecks] #1526199
10/31/13 09:59 AM
10/31/13 09:59 AM
BDW Offline
BDW  Offline
Any way to adapt a 2 belt pully for AC small block car?
Re: Internally regulated alternators - good or bad? [Re: jbeintherockies] #1526200
10/31/13 01:16 PM
10/31/13 01:16 PM
dogdays Offline
dogdays  Offline
How do you suppose internal regulators work? They regulate output based on battery voltage same as external ones. They just have the regulator miniaturized and mounted in or on the alternator.
There is always at least one connection between the alternator and the battery, isn't there?
R.
Re: Internally regulated alternators - good or bad? [Re: dogdays] #1526201
10/31/13 01:26 PM
10/31/13 01:26 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: Internally regulated alternators - good or bad? [Re: ademon] #1526202
10/31/13 08:04 PM
10/31/13 08:04 PM
Aurora, CO
Aurora, CO
This is where I get confused. If the alternator is holding 14.4 volts at all times, doesn't that mean the battery will get overcharged at some point?
Re: Internally regulated alternators - good or bad? [Re: jbeintherockies] #1526203
10/31/13 10:01 PM
10/31/13 10:01 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
No. The voltage remains constant but the current flowing to the battery is negligible. Lead acid batteries love constant voltage sources while NiCads, LiOn and some others like constant current sources.
Craig
Re: Internally regulated alternators - good or bad? [Re: denfireguy] #1526204
11/01/13 12:25 AM
11/01/13 12:25 AM
IN
ahy Offline
ahy  Offline
IN
With a one wire, any voltage drop in the charge wire will result in lower voltage to the electrical system and battery. A really big charge wire from alternator to battery can help overcome this problem but one wire is not optimal for voltage regulation. Most 1 wire alternators are available with 3 wire setup or convertible to 3 wire.
Re: Internally regulated alternators - good or bad? [Re: jbeintherockies] #1526205
11/01/13 10:37 AM
11/01/13 10:37 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
The biggest drawback of internal regulation is the heat generated by the alternator does not contribute to the longevity of the electronics in the regulator. That is why Mother Mopar did not do that when they invented the first mass produced standard equipment alternator.
Craig
Re: Internally regulated alternators - good or bad? [Re: jbeintherockies] #1526206
11/01/13 12:05 PM
11/01/13 12:05 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
No as the regulators job is to maintain battery voltage in 13.0 to 15.0 area depending on outside temps. At 14.4 it would most likely be in the 30 to 60 degree outside temps but it can hold 14.4 volts at 3 to 5 amps or at 25 amps depending on the battery charge and the load from the rest of the electrical units on the car. Say you leave your lights on and run the battery down. When you start the car it may take about 25 to 30 amps just going in the battery to hold 14.4 volts. But as the battery volts comes up the regulator cuts back the alt output. So once the battery is just about fully charged it may only take in 3 or 4 amps to hold the voltage at 14.4 or whatever the target voltage is depending on outside temps. If you have a charged battery but turn on your heater and lights then the alt may put out 40 amps as 37 amps may be supplying the lights and heater and 3 amps to the battery to hold the proper battery volts. Ron
Re: Internally regulated alternators - good or bad? [Re: denfireguy] #1526207
11/01/13 12:06 PM
11/01/13 12:06 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I have a Internally regular Delco Remy on my 440 and its been there for 13 years. Never given me a problem, always given me 14.6 volts ...I just have to rod check when I start to turn it on at 1500rpm...Custom made brackets for this.
I installed the single wire Powermaster 140amp on my buddy's 72 Roadrunner about 2 months ago and he loves it too. Just remember to run an inline MegaFuse just in case something lets go and you don't run mass Voltage to the battery..Stock bracketswork for this but you have to remove the pulley & 3-bolts to rotate the housing to clear the rear terminal.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Internally regulated alternators - good or bad? [Re: jbeintherockies] #1526208
11/01/13 12:39 PM
11/01/13 12:39 PM
AndyF Offline
AndyF  Offline
I've sold hundreds of the bracket kits over the past 10 years to adapt the Toyota Denso alternator to SB, BB and Hemi engines. Most everyone is really happy with the improvement. The Denso design reflects several decades of engineering development over the original Mopar design but it still has the look and reliability of an OEM part.
Re: Internally regulated alternators - good or bad? [Re: AndyF] #1526209
11/01/13 03:56 PM
11/01/13 03:56 PM
Columbus, GA
Columbus, GA
As previously mentioned I am one of those really happy people. Thanks for engineering those brackets!
Re: Internally regulated alternators - good or bad? [Re: AndyF] #1526210
11/01/13 08:55 PM
11/01/13 08:55 PM
Aurora, CO
Aurora, CO
According to the Mancini site, the brackets will not work with a driver-side inlet water pump. Of course, that is the style of water pump on my car. Dang' it!
http://chucker54.stores.yahoo.net/maenalbr.html
My radiator (expensive aluminum version) is a driver side outlet, which will make it a challenge to cobble together a lower radiator hose if I decide to switch to a passenger-side inlet water pump.
Do they sell a lower radiator hose for what I need? If not, has anyone cobbled one together to get a newer style water pump to work with an older style radiator outlet?
Re: Internally regulated alternators - good or bad? [Re: jbeintherockies] #1526211
11/02/13 12:13 AM
11/02/13 12:13 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Is that just because the fore and aft spacing is all setup for a aluminum 70-up water pump?
I mocked up and ran the 45 amp Suzuki Samurai Denso alternator on a 68 Cast Iron water pump. You just have to do the spacing yourself and modify some brackets. Didn't really modify the 3 bolt alternator bracket at all for this.
The alternator need to be moved back about equal to a full groove. There wasn't much space behind the alternator at all.
Re: Internally regulated alternators - good or bad? [Re: autoxcuda] #1526212
11/02/13 12:31 AM
11/02/13 12:31 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Detail side shot
Re: Internally regulated alternators - good or bad? [Re: autoxcuda] #1526213
11/02/13 12:41 AM
11/02/13 12:41 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Another shot showing pulleys and brackets better.
Was mocking up the alternator and MSD E-curve on the old motor first. Just to make sure there were no issue on a new motor start-up.
You can really see how the alternator pulley is too far forward (...or the fan pulley groove is too far back)
Re: Internally regulated alternators - good or bad? [Re: autoxcuda] #1526214
11/02/13 09:04 AM
11/02/13 09:04 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
I have a Powermaster 1 wire 75A alternaor. Works great, fits fine.
