Cylinder wall to piston clearance with Nitrous.
#1525957
10/30/13 03:08 PM
10/30/13 03:08 PM
Posts: 1,301 Penna
70satelliteguy
Penna
Ross recommends .006 clearance with bore size of 4.50 and above. They also recommend an additional .002 with Nitrous use over 250 hp.That comes to 008 total. That seems like A lot of clearance! What are you guys with Nitrous assisted motors 4.5 or larger running? Thanks Mike
Re: Cylinder wall to piston clearance with Nitrous.
[Re: Biginchmopar]
#1525959
10/30/13 03:16 PM
10/30/13 03:16 PM
Posts: 47 CO
Nitrojunkee
CO
That's not alot. Put it where they want it. Good Luck!
x2 I Assume they are Ross forged pieces? You may get a little slap when It's cold, but that's not a lot of clearance.
Run it how they are saying, and you'll be golden.
[Re: Nitrojunkee]
#1525960
10/30/13 03:40 PM
10/30/13 03:40 PM
Posts: 1,301 Penna
70satelliteguy
Penna
Yes they are Ross forged pistons. I just did not want to put it back together at 008 if there would be a problem! "You may get a little slap when It's cold" I will never be able to hear it anyway Thanks MIke
[Re: cudaman1969]
#1525962
10/30/13 03:46 PM
10/30/13 03:46 PM
Posts: 1,301 Penna
70satelliteguy
Penna
"Fast Hemi's run .012 .A secret they don't tell." Really Is there a performance advantage to that? Mike
[Re: 70satelliteguy]
#1525963
10/30/13 03:48 PM
10/30/13 03:48 PM
Posts: 6,295 U.S.
moparniac
U.S.
On my diamond pistons at 4.505 the piston called for .0065 clearance.
Mopar Performance
#1525964
10/30/13 04:06 PM
10/30/13 04:06 PM
Posts: 47 CO
Nitrojunkee
CO
Exactly!
FYI, Diamond recommended .0075 on my custom blower pistons... Minus .002 for hard anodized coating. So I think you're right on!
#1525965
10/30/13 08:25 PM
10/30/13 08:25 PM
Posts: 7,506 Az
Crizila
Az
A lot depends on the length of the skirt. I run a pretty short skirt on my forged Icons and their blower application recommended .008 to .010". I set them at .008". When I pulled it down recently, there was some skirt scuffing going on. New build will get .007".
Fastest 300
#1525966
10/30/13 11:28 PM
10/30/13 11:28 PM
Posts: 8,349 fredericksburg,va
cudaman1969
fredericksburg,va
Mike
my older (90s) had .012 much newer (big name) had .011 whatever works,has to be a reason, they don't make make mistakes like that. Personally i don't know but what i measured. Pay them 250 grand and they will tell. Ask something on SSAH and hear the quiet.
[Re: 572charger]
#1525968
10/31/13 03:41 PM
10/31/13 03:41 PM
Posts: 1,301 Penna
70satelliteguy
Penna
"my 4.50 bore are at 9 thou so i can run my fogger at 300 hp " 572 are those Ross pistons? Do you have any noticeable blowby? Thanks Mike
[Re: Cab_Burge]
#1525970
11/03/13 08:01 AM
11/03/13 08:01 AM
Posts: 1,629 pa
572charger
pa
they are diamond pistons no blow by ring end gap is 28 on the top and 30 on the second . most of the time i put about 6.5 thou on a piston to wall on a street motor
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
