Cylinder wall to piston clearance with Nitrous. #1525957
10/30/13 03:08 PM
10/30/13 03:08 PM
Penna
70satelliteguy Offline OP
Penna
Ross recommends .006 clearance with bore size of 4.50 and above. They also recommend an additional .002 with Nitrous use over 250 hp.That comes to 008 total. That seems like A lot of clearance!
What are you guys with Nitrous assisted motors 4.5 or larger running?
Thanks Mike
Re: Cylinder wall to piston clearance with Nitrous. [Re: 70satelliteguy] #1525958
10/30/13 03:10 PM
10/30/13 03:10 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
That's not alot. Put it where they want it. Good Luck!
Re: Cylinder wall to piston clearance with Nitrous. [Re: Biginchmopar] #1525959
10/30/13 03:16 PM
10/30/13 03:16 PM
CO
N
Nitrojunkee Offline
Nitrojunkee  Offline
N
CO
x2 I Assume they are Ross forged pieces? You may get a little slap when It's cold, but that's not a lot of clearance.
Run it how they are saying, and you'll be golden.
Re: Cylinder wall to piston clearance with Nitrous. [Re: Nitrojunkee] #1525960
10/30/13 03:40 PM
10/30/13 03:40 PM
Penna
Penna
Yes they are Ross forged pistons. I just did not want to put it back together at 008 if there would be a problem!
"You may get a little slap when It's cold"
I will never be able to hear it anyway
Thanks MIke
Re: Cylinder wall to piston clearance with Nitrous. [Re: Nitrojunkee] #1525961
10/30/13 03:41 PM
10/30/13 03:41 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Fast Hemi's run .012 .A secret they don't tell.
Re: Cylinder wall to piston clearance with Nitrous. [Re: cudaman1969] #1525962
10/30/13 03:46 PM
10/30/13 03:46 PM
Penna
Penna
"Fast Hemi's run .012 .A secret they don't tell."
Really Is there a performance advantage to that?
Mike
Re: Cylinder wall to piston clearance with Nitrous. [Re: 70satelliteguy] #1525963
10/30/13 03:48 PM
10/30/13 03:48 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
On my diamond pistons at 4.505 the piston called for .0065 clearance.
Mopar Performance
Re: Cylinder wall to piston clearance with Nitrous. [Re: 70satelliteguy] #1525964
10/30/13 04:06 PM
10/30/13 04:06 PM
CO
N
Nitrojunkee Offline
Nitrojunkee  Offline
N
CO
Thanks MIke
Exactly!
FYI, Diamond recommended .0075 on my custom blower pistons... Minus .002 for hard anodized coating. So I think you're right on!
Re: Cylinder wall to piston clearance with Nitrous. [Re: 70satelliteguy] #1525965
10/30/13 08:25 PM
10/30/13 08:25 PM
Az
Crizila Offline
Crizila  Offline
Az
A lot depends on the length of the skirt. I run a pretty short skirt on my forged Icons and their blower application recommended .008 to .010". I set them at .008". When I pulled it down recently, there was some skirt scuffing going on. New build will get .007".
Fastest 300
Re: Cylinder wall to piston clearance with Nitrous. [Re: 70satelliteguy] #1525966
10/30/13 11:28 PM
10/30/13 11:28 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Mike
my older (90s) had .012 much newer (big name) had .011
whatever works,has to be a reason, they don't make make mistakes like that. Personally i don't know but what i measured. Pay them 250 grand and they will tell. Ask something on SSAH and hear the quiet.
Re: Cylinder wall to piston clearance with Nitrous. [Re: cudaman1969] #1525967
10/31/13 07:01 AM
10/31/13 07:01 AM
pa
572charger Offline
572charger  Offline
pa
my 4.50 bore are at 9 thou so i can run my fogger at 300 hp
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Cylinder wall to piston clearance with Nitrous. [Re: 572charger] #1525968
10/31/13 03:41 PM
10/31/13 03:41 PM
Penna
Penna
"my 4.50 bore are at 9 thou so i can run my fogger at 300 hp "
572 are those Ross pistons? Do you have any noticeable blowby?
Thanks Mike
Re: Cylinder wall to piston clearance with Nitrous. [Re: 70satelliteguy] #1525969
10/31/13 09:56 PM
10/31/13 09:56 PM
Cab_Burge Online work
Cab_Burge  Online Work
I have use Ross pistons on many builds, I always specify the close tolerance alloy so the rings will stay sealed better when running I add .0005 additional piston the cylinder wall to what they specify on thier literature. That alloy seems to be delicate so more clearances help keep the piston skirts from rubbing on the cylinder walls To tight, even .0001 to tght, will fail Looser is better on race motors, don't let them rub the cylinder walls
Re: Cylinder wall to piston clearance with Nitrous. [Re: Cab_Burge] #1525970
11/03/13 08:01 AM
11/03/13 08:01 AM
pa
572charger Offline
572charger  Offline
pa
they are diamond pistons no blow by ring end gap is 28 on the top and 30 on the second . most of the time i put about 6.5 thou on a piston to wall on a street motor
