Milling heads for Compression
#152565
11/17/08 05:54 PM
11/17/08 05:54 PM
Posts: 964 Nanaimo, B.C.
GwaiiEagle
Mannix
Mannix
Nanaimo, B.C.
How much can you safely mill the Eddy 84cc heads in an effort to increase compression?
Re: Milling heads for Compression
[Re: Hughes]
#152567
11/18/08 01:45 PM
11/18/08 01:45 PM
GwaiiEagle, I assume you are asking how much can you safely mill. We have milled some of the RPM heads as much as .100" and it was fine but normally we like to stay at about .085". Kevin
what did they cc at with .100 cut?
[Re: GwaiiEagle]
#152570
11/19/08 08:52 AM
11/19/08 08:52 AM
Posts: 4,799 ILL
MLR426
ILL
At .085 off the head deck you should remove .1045 off the intake side.
For every .010 cut from the head deck, you cut .0123 off intake. Example 100 off the head deck, you cut the intake side .123 I also try to cut the intake runner side of the head, it raises the port entry of the runner. And when you cut the intake side of the head you can use any intake manifold on the engine. After cutting the intake side of the head you need to port the intake runner to match up good with the port entry.
logan426
[Re: MLR426]
#152571
11/19/08 09:03 AM
11/19/08 09:03 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
right. if you cut the intake to fit the head, then you now have an intake that's only good for that engine/head combination.
if you cut the head to fit the intake, you keep the interchangability of the intake...good if you change your engine combo later, or sell the used intake to help finance a new one, etc.
**Photobucket sucks**
