Re: A little sunday excitment. Not what I was hoping for!
[Re: Dragula]
#1525141
10/29/13 01:38 PM
10/29/13 01:38 PM
Posts: 2,224 Arlington, Tx.
BJS racing
Arlington, Tx.
There is absolutely no adjustment that can be made on the chassis. You can adjust the toe on the front and that be all there is.
Back in the swing of things at Painless again! Great to be back!
[Re: BJS racing]
#1525144
10/29/13 01:53 PM
10/29/13 01:53 PM
Posts: 8,165 Left Coast
BobR
Left Coast
Have you scaled the car?
[Re: BJS racing]
#1525148
10/29/13 03:10 PM
10/29/13 03:10 PM
Posts: 12,410 Taxes & Virus's R-US, NY
Dragula
Well, that is an issue. I have seen a couple of different chassis set-ups, but is there no way to aim the rear, or change the chassis flex with a lengthening or shortening of a mid chassis bar? Somthing caused it to drive left...I like the tires thought...VC breather leak then? A picture of this non-adjustable chassis might help...
[Re: BJS racing]
#1525150
10/29/13 04:51 PM
10/29/13 04:51 PM
Dragula
I don't have may pics of the car right now. Dennis the founder of Painless owns the car and I am driving it. This is actually a 15-20 year old new chassis that was hanging in a guys shop that he never did anything with. Its a Neil & Parks chassis? I don't remember exactly who but someone like that. It was built as a top fuel fed car back then.
I can tell you, that much Hp pointed in the wrong direction off the launch is just scary. If you know you didn't get somthing slippery under that tire or had your air pressure way off,look for loose/ bent bolts, bent axle, somthing...It picked the tires up after it launched and steered left. I have tinkered with four links and had a similar situation, we bent all the brackets on it. Use a 6" scale and start looking at it...
