Page 5 of 9 1 2 3 4 5 6 7 8 9
Re: Rocker Geometry Measurements [Re: HotRodDave] #1524376
10/30/13 11:20 PM
10/30/13 11:20 PM
AndyF Offline
AndyF  Offline
Maybe some of you guys should look at that guys kit, it moves the shaft up to correct geometry and back to center the contact patch, the only compromise I see is the PR geometry will get worse, not a big deal on a BB but a SB is already bad. Of course a W2 is worstest yet and they can rev good so
The CAD drawings I've done say the shaft has to move down to correct geometry with a high lift cam. Moving the shaft up makes things worse on every simulation that I've run.
Re: Rocker Geometry Measurements [Re: Crizila] #1524377
10/31/13 08:18 AM
10/31/13 08:18 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We think this post needs to start over and maybe this guy can provide us with more detailed information on how his kits can correct common issues, and after we understand how it works, then he won't have to do a sales pitch, we will be ringing his phone off the hook.
I know it would be of interest to us since we spend so much time on valvetrain corrections and end up with different fixes that are a priority for each build.
I hope he comes back and helps us and himself by educating us on his method and product.
Re: Rocker Geometry Measurements [Re: AndyF] #1524378
10/31/13 09:32 AM
10/31/13 09:32 AM
Canada
onig Offline
onig  Offline
Canada
Andy,
Have you done this with the rocker shaft pedestals.
I am guessing that you machined the pedestals down some; yes?
Also what are you considering high lift cams, 700, 800, 900?
Onig
69 Dart
Re: Rocker Geometry Measurements [Re: onig] #1524379
10/31/13 12:16 PM
10/31/13 12:16 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Andy I agree with you, with increased lift rocker shaft would have to be lowered assuming geometry is optimized before the additionial lift is added. I can also see how the rocker would need to be raised to compensate for the relocation of the contact point by adding the roller. This is what I have learned from these discussions Bottom line is there is only one location that is optimum for each type rocker, ratio and lift combination. The by product of your effort will be a rocker that is centered on the valve stem when the valve is on the seat and at full lift. What is acceptable other than being in this blue printed location I have no idea. Thanks to the OP for starting the discussion.
Getting old just means you were smarter than some and luckier than others.
Re: Rocker Geometry Measurements [Re: B G Racing] #1524380
10/31/13 12:33 PM
10/31/13 12:33 PM
Q
Quicktree Offline
Quicktree  Offline
Q
heck that makes to much sense
Re: Rocker Geometry Measurements [Re: Quicktree] #1524381
10/31/13 01:50 PM
10/31/13 01:50 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Sorry ,Tony I was think out loud again.I keep my mind/mouth closed from now on.
Re: Rocker Geometry Measurements [Re: AndyF] #1524382
10/31/13 01:51 PM
10/31/13 01:51 PM
Washington
SuperStock68Dart Offline
Washington
Re: Rocker Geometry Measurements [Re: AndyF] #1524383
10/31/13 01:57 PM
10/31/13 01:57 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
FWIW, my Stage VIs required raising the shafts to get the geometry straightened out + lash caps, along w/ test-fitting a variety of rocker arms to come up w/ a combination that actually worked correctly. From what I've heard, that wasn't typical for most Stage VIs, but it's what was required with my particular set.
I think the approach required depends on the application, the particular parts used, and the rocker geometry results (e.g. Jim Miller's Mid-Lift design vs. Jesel's theory) you're looking to achieve.
Re: Rocker Geometry Measurements [Re: BradH] #1524384
10/31/13 02:04 PM
10/31/13 02:04 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We have seen rockers that need to be raised,lowered,moved toward the intake side and to the exhaust side.
Re: Rocker Geometry Measurements [Re: B G Racing] #1524385
10/31/13 02:27 PM
10/31/13 02:27 PM
Delray beach, Florida
P
Performance Only Offline
P
Then add some .100" length valves (or longer) in the mix and there's a whole host of geometry issues created. The actual geometry itself is pretty basic. achieving it is the hard part.
machine shop owner and engine builder
Re: Rocker Geometry Measurements [Re: Performance Only] #1524386
10/31/13 02:45 PM
10/31/13 02:45 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Brad I would like to see an engine with one theory applied on one head and the other theory on the other. Then check the lift at the valve to see which achieves the most lift at the valve. One thing for sure the set up that has the rocker 90 degrees in relation to the valve at mid lift will have the least amount of scrub.
Re: Rocker Geometry Measurements [Re: dannysbee] #1524387
10/31/13 04:09 PM
10/31/13 04:09 PM
BradH Offline
BradH  Offline
I played around with this stuff years ago looking to see what happened when I set up the valve train to achieve different end goals. It's not just a "peak lift thing"; you can also measure differences in net duration at various points across the lift curve, as well as variations in the scrub patterns and where in the lift curve the majority of the scrubbing takes place.
Now, if you asked me what my findings were... I can't tell you where those notes ended up, nor would I claim my "testing" was precise enough to make any specific claims one way or the other.
I will say that the final configuration I worked out for those Stage VIs resulted in a nicely centered sweep across the valve tip that was somewhere in the .050-.060" width range over .600" lift. It followed Jim Miller's Mid-Lift concept, rather than Jesel's, and the guides showed basically no wear after about 5K miles when I sent the heads back to Dwayne Porter to be touched up.
Re: Rocker Geometry Measurements [Re: dannysbee] #1524388
10/31/13 05:03 PM
10/31/13 05:03 PM
AndyF Offline
AndyF  Offline
Mid lift provides the least amount of scrub. Low point (2/3 lift) gives you the least amount of scrub under load. That is, the scrub occurs while the load is low and then when the load is high there is very little scrubbing action.
I think most of the serious valve train designers migrated to the low pivot point design a number of years back. The math is fairly complicated but if you put the rocker arm perpendicular to the valve stem at 2/3 lift you're in the ballpark. The scrub pattern is larger than with the mid-lift design, but the sideways force applied to the valve goes down.
Re: Rocker Geometry Measurements [Re: AndyF] #1524389
10/31/13 05:28 PM
10/31/13 05:28 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I wouldn't hesitate to say these last two posts are over the heads of 95% of the readers of this discussion. Oh yeah wher's my free stuff.
Re: Rocker Geometry Measurements [Re: cudaman1969] #1524390
10/31/13 05:33 PM
10/31/13 05:33 PM
California
mickm Offline
mickm  Offline
California
not sure why that's important.
are they over my head? more or less. but i still read them and learn from them, and even if i don't completely get it, it still either expands my knowledge of the subject or enables me to understand things in a little more detail the next time i read or discuss these concepts.
Re: Rocker Geometry Measurements [Re: mickm] #1524391
10/31/13 06:10 PM
10/31/13 06:10 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Why that's important? If a guys got a bullet in him I could remove it and sew him up but I would rather let a doctor do it right and PAY him. The man obviously has a service to offer that's complicated and most couldn't get it right. It's called capitalism. Every part of the engine has to be bought, why not this? Or just let him give it away?
Re: Rocker Geometry Measurements [Re: cudaman1969] #1524392
10/31/13 06:38 PM
10/31/13 06:38 PM
California
mickm Offline
mickm  Offline
California
ok, i get what you are saying, just wasn't clear from the first post...
Re: Rocker Geometry Measurements [Re: cudaman1969] #1524393
10/31/13 06:47 PM
10/31/13 06:47 PM
P
P
Like Ted the moderator said, the OP should put up a post offering his kit and his service. It'll ultimately end up in a different forum but it will get the word out he has something to offer for those that want or need it.
Re: Rocker Geometry Measurements [Re: cudaman1969] #1524394
10/31/13 06:59 PM
10/31/13 06:59 PM
AndyF Offline
AndyF  Offline
The concept would be easier to communicate if I took the time to post a picture. Or better yet, a short video would fully explain it in just a few frames.
I first read about the low pivot concept in a GM engine book years ago. The author didn't explain it fully but it sounded interesting. Years later I finally sat down at the CAD terminal and figured it out. The math is too complex for me so I solved the equation graphically. What you're trying to do is to solve the smallest product of load and scrub. When the valve is closed the load is small so you allow a lot of scrub. When the valve is full lift you're at max load so that is when you want zero scrub.
When you solve the equation you end up with the rocker arm perpendicular to the valve stem at about 2/3 of lift. This is below the mid-point theory which is more popular. The mid-lift approach is a simple approach that works pretty well in most applications. But if you're setting up something with 800 or 900 lbs on the nose then you might want to minimize the scrub under load.
Re: Rocker Geometry Measurements [Re: AndyF] #1524395
10/31/13 07:56 PM
10/31/13 07:56 PM
California
mickm Offline
mickm  Offline
California
yup, that makes it perfectly clear! thanks!
