Dakota frame swaps #1524260
10/27/13 06:32 PM
10/27/13 06:32 PM
Canada
demon Offline OP
demon  Offline OP
Canada
I have a Dakota that I plan to tear off the body and swap on an older body, probably a 49-59 Studebaker pickup but possibly an old Dodge body.
Let's hear about your Dakota swaps and see some pictures.
Re: Dakota frame swaps [Re: demon] #1524261
10/27/13 09:53 PM
10/27/13 09:53 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
https://board.moparts.org/ubbthreads/show...e=0#Post7880770
The frame is wider than an s10 so you can't drop them as low. I used all the brake lines off the truck which was nice. Had to move the motor back around five inches. Swapping to five bolt pattern just rotors on the front and axels and drums in the rear.
Look in the street rodder forum as a couple more have been done there..
Re: Dakota frame swaps [Re: moparpollack] #1524262
10/27/13 11:46 PM
10/27/13 11:46 PM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
Here's a pic of my 57 on most of an 88 dak frame. I actually joined the dak forward section with the rear half of the 57 frame to get the stance that I wanted.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: Dakota frame swaps [Re: demon] #1524263
10/28/13 11:50 PM
10/28/13 11:50 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Old race car look is a 48 Plymouth business coupe on a Dakota chassis. Used the Dakota floor pan & firewall. Moved the "cab" back 7" and cut 8" out of the wheel base between the cab and the fuel tank so the wheel bases matched. The Dakota was a standard cab long box, the coupe had 114" wheel base (if I remember correctly, old age sucks). Used the Dakota drive train as well, the motor & trans were moved back 7" as well. Shortened the drive shaft. The car has been on the road for 2 full summers and has logged about 8,000 miles. It is a work in progress, but will never be "pretty". Gene
