Page 6 of 7 1 2 3 4 5 6 7
Re: 2014 plans?? [Re: fullmetaljacket] #1524125
12/10/13 10:56 PM
12/10/13 10:56 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Conquer the world and try to go faster.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: 2014 plans?? [Re: Adobedude] #1524126
12/12/13 10:51 PM
12/12/13 10:51 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I just want to get my Duster done and go cruisin!
Re: 2014 plans?? [Re: ProSport] #1524127
12/13/13 12:10 AM
12/13/13 12:10 AM
K
Kiddart Offline
Kiddart  Offline
K
Just do a little re-wire. get rid of all the spagetti!!
Thank you
Kiddart
Re: 2014 plans?? [Re: Kiddart] #1524128
12/14/13 05:03 PM
12/14/13 05:03 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
My only plans are....
1. To get the Rocky in the tens...looks Like I have to take some gear out of it and get more fuel to the motor to do it.
2 To finish porting the 337 manifold and try it out on the 517 against the Max ported Indy Dual Plane.
3. To build the 440" small block W2 Tunnel Ram motor...even though I don't have anything to drop it in at the moment
WIZE
In Car:
Re: 2014 plans?? [Re: Dragula] #1524129
12/26/13 08:43 PM
12/26/13 08:43 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
For the 2013 Championship winning Duster, we have a small list of upgrades in progress:
1-Wilwoods on all four corners got the fronts almost ready to put on the car, waiting on two bolts from Wilwood, and the rears are mounted, and the brake lines showed up today...
2-Relocate the master cylinder to the chassis
3-New slicks
4-Finish the tin work for the interior
5-Finish painting the floor and cage (in progress, along with a new seat)
6-Bigger fire extinguisher
7-Cut out rear cross sub-frame that's badly notched for clearance and install a new tubular one (Complete)
8-Fix oil leak
9-Tubular upper A-arms (almost ordered a set today)
10-SV1 carburator (got a quote for one, but found a used one for a good price, & sending the payment ASAP!)
11-re-scale the car
12-Put a real fuel pump in the car Probably a MagnaFuel 275....(Just added that one)
Whatever money & time allows
Re: 2014 plans?? [Re: Dragula] #1524130
12/27/13 12:45 AM
12/27/13 12:45 AM
Out West
408strokerdart Offline
Out West
New stainless step headers, hopefully a new intake manifold and loose a couple more pounds. Hopefully 5.teens are in my future. Make the car go under 1.2 consistently in 60'. Pile up some win tickets. Go to "The Strip"....
Re: 2014 plans?? [Re: 408strokerdart] #1524131
12/27/13 03:21 AM
12/27/13 03:21 AM
campbell river B.C
mopartoby Offline
mopartoby  Offline
campbell river B.C
Hmmm ...... drop my 1097hp b1 572 in my 25.1e tube chassis cuda and
Re: 2014 plans?? [Re: Mr.Yuck] #1524132
12/27/13 05:23 AM
12/27/13 05:23 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
To get out at least a few times, and to get out early in the year for a Test & Tune day, so I can actually spend some time finding some ET.
We'll see if my daughters Fastpitch schedule allows for this, though.
Re: 2014 plans?? [Re: StealthWedge67] #1524133
12/27/13 09:54 AM
12/27/13 09:54 AM
tboomer Offline OP
tboomer  Offline OP
As of now I don't know What is going to happen for sure! Funds are getting low! I should be able to get new shocks for the front but any glass parts may be out of reach! If I don't find 2 ounces of gold my entire season may be in jeopardy!!
Re: 2014 plans?? [Re: tboomer] #1524134
12/27/13 03:31 PM
12/27/13 03:31 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
win more of these
and finish this
"Just a Bracket car dressed up like a streetcar"
Re: 2014 plans?? [Re: Just-a-dart] #1524135
12/27/13 08:18 PM
12/27/13 08:18 PM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
Get this out of the trailer more than twice and actually run it down a track again.
Of course, that means new rear tires, probably an anti-roll bar, and I'll want to do the tighter converter it needs. Oh, and have to get the belts re-cert'ed. With a right converter, it'll need a window net, chassis cert (and that will require finally adding the diagonal down bars behind the seats).
Maybe I'll just leave it in the trailer for another year.
Re: 2014 plans?? [Re: G_bob] #1524136
12/27/13 08:36 PM
12/27/13 08:36 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
"HOPEFULLY" get a 543 pump gas motor done before the March Meet......YA...junkyard 440 most likely will still be in for the 2014 MM....LOL
Re: 2014 plans?? [Re: Chassisman] #1524137
12/28/13 12:43 AM
12/28/13 12:43 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Building a KILLA 528 cubic inch motor and painting my T/A hood flat black!!!!
Re: 2014 plans?? [Re: ccdave] #1524138
12/28/13 12:55 AM
12/28/13 12:55 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
getting this 10 sec thing installed.....
Re: 2014 plans?? [Re: Dragula] #1524139
01/04/14 12:11 AM
01/04/14 12:11 AM
1-Wilwoods on all four corners Got the fronts ready to put on the car, waiting on two bolts from Wilwood, and the rears are mounted, and the brake lines showed up today...
3-New slicks
8-Fix oil leak
10-SV1 carburator Arrived today!
11-re-scale the car
13-Install Ultra Mini Alternator Arrived today!
My SV1 arrived today!!!
Also should have almost 70lbs out of the car between the brakes and the super mini alternator...And it is waaaay too cold to go out and work on anything
Re: 2014 plans?? [Re: Forest] #1524140
01/04/14 02:13 AM
01/04/14 02:13 AM
australia
charger410 Offline
charger410  Offline
australia
I am collecting parts to replace the 408/727 from my Stratus with a low deck 540 w/ B1 heads and a Glide. Should be a solid 300HP upgrade
Always thought your car was wasted with that small block, good choice on replacement, plenty of HP in that combination.
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
Re: 2014 plans?? [Re: charger410] #1524141
01/04/14 12:28 PM
01/04/14 12:28 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Car is at the chassis shop getting lowered 2 inch. To do this they built a custom sump, narrowed the rear and inboarded the leaf springs.
Whilst it was there it also had a rear anti roll bar fitted, 'chute mount, chrome moly prop, D/A rear shocks and Wilwoods fitted to the Dana.
Should have it back next week after being baselined with the 580 motor.
All we have to do after that is beef the 'box up some more and the 655 can go in
Then we have the 68 Barracuda to do, 'box is done and the motor for this starts very soon, just a warmed over 318 with mildly worked '308 heads. Should be a fun daily driver.
Re: 2014 plans?? [Re: Tig] #1524142
01/04/14 07:15 PM
01/04/14 07:15 PM
jax. fla.
70Dustmite440 Offline
jax. fla.
Maybe coming out of retirement!! Will see...
8sec. street car, been there done that. Quitting when your ahead isn't the same as quitting.
[img]https://scontent-atl.xx.fbcdn.net/hphoto...amp;oe=55DB3E4C[/img]
https://www.facebook.com/eric.norton.1048
R.I.P.UN.
Re: 2014 plans?? [Re: 70Dustmite440] #1524143
01/06/14 11:58 PM
01/06/14 11:58 PM
New brakes comming along...
Re: 2014 plans?? [Re: Dragula] #1524144
01/07/14 02:08 AM
01/07/14 02:08 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Pump gas baby! Heads are up at Dwaynes and pistons are in the works. Time to drive the stupid thing after sitting for 5 years
