Re: 2014 plans??
[Re: fullmetaljacket]
#1524125
12/10/13 10:56 PM
12/10/13 10:56 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
Conquer the world and try to go faster.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
Re: 2014 plans??
[Re: Adobedude]
#1524126
12/12/13 10:51 PM
12/12/13 10:51 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
I just want to get my Duster done and go cruisin!
Re: 2014 plans??
[Re: Kiddart]
#1524128
12/14/13 05:03 PM
12/14/13 05:03 PM
Posts: 9,892 Weddington, N.C.
Streetwize
Weddington, N.C.
My only plans are.... 1. To get the Rocky in the tens...looks Like I have to take some gear out of it and get more fuel to the motor to do it. 2 To finish porting the 337 manifold and try it out on the 517 against the Max ported Indy Dual Plane. 3. To build the 440" small block W2 Tunnel Ram motor...even though I don't have anything to drop it in at the moment ![](/ubbthreads/images/graemlins/blush.gif)
Re: 2014 plans??
[Re: Dragula]
#1524129
12/26/13 08:43 PM
12/26/13 08:43 PM
Posts: 12,418 Taxes & Virus's R-US, NY
Dragula
For the 2013 Championship winning Duster, we have a small list of upgrades in progress:
1-Wilwoods on all four corners got the fronts almost ready to put on the car, waiting on two bolts from Wilwood, and the rears are mounted, and the brake lines showed up today... 2-Relocate the master cylinder to the chassis 3-New slicks 4-Finish the tin work for the interior 5-Finish painting the floor and cage (in progress, along with a new seat) 6-Bigger fire extinguisher 7-Cut out rear cross sub-frame that's badly notched for clearance and install a new tubular one (Complete) 8-Fix oil leak 9-Tubular upper A-arms (almost ordered a set today) 10-SV1 carburator (got a quote for one, but found a used one for a good price, & sending the payment ASAP!) 11-re-scale the car
12-Put a real fuel pump in the car Probably a MagnaFuel 275....(Just added that one) Whatever money & time allows
Re: 2014 plans??
[Re: Mr.Yuck]
#1524132
12/27/13 05:23 AM
12/27/13 05:23 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
To get out at least a few times, and to get out early in the year for a Test & Tune day, so I can actually spend some time finding some ET. We'll see if my daughters Fastpitch schedule allows for this, though. ![](/ubbthreads/images/graemlins/shruggy.gif)
Re: 2014 plans??
[Re: Just-a-dart]
#1524135
12/27/13 08:18 PM
12/27/13 08:18 PM
Posts: 3,616 Riverside, Ca
G_bob
Riverside, Ca
Get this out of the trailer more than twice and actually run it down a track again. Of course, that means new rear tires, probably an anti-roll bar, and I'll want to do the tighter converter it needs. Oh, and have to get the belts re-cert'ed. With a right converter, it'll need a window net, chassis cert (and that will require finally adding the diagonal down bars behind the seats). Maybe I'll just leave it in the trailer for another year. ![](/ubbthreads/images/graemlins/tongue.gif)
Re: 2014 plans??
[Re: charger410]
#1524141
01/04/14 12:28 PM
01/04/14 12:28 PM
Posts: 2,937 A shed in England
Tig
A shed in England
Car is at the chassis shop getting lowered 2 inch. To do this they built a custom sump, narrowed the rear and inboarded the leaf springs. Whilst it was there it also had a rear anti roll bar fitted, 'chute mount, chrome moly prop, D/A rear shocks and Wilwoods fitted to the Dana. Should have it back next week after being baselined with the 580 motor. All we have to do after that is beef the 'box up some more and the 655 can go in ![](/ubbthreads/images/graemlins/grin.gif) Then we have the 68 Barracuda to do, 'box is done and the motor for this starts very soon, just a warmed over 318 with mildly worked '308 heads. Should be a fun daily driver. ![](/ubbthreads/images/graemlins/grin.gif)
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
