Tires #152362
11/17/08 01:55 PM
11/17/08 01:55 PM
Mesa, Az
GETX Offline OP
GETX  Offline OP
Mesa, Az
Can anyone tell me if a 70 Road Runner can handle 255x60x15 tires all the way around without any clearence problems? or what would be a better choice? Thanks for any info. that can be provided.
Re: Tires [Re: GETX] #152363
11/17/08 02:02 PM
11/17/08 02:02 PM
La Grange, Ky
70rrclone Offline
70rrclone  Offline
La Grange, Ky
i have 275/60/15 on the rear and 245/60/15's
on the front with no issues. looks like a 255/60 would be just fine. mine is also lowered 3" front and rear. i will be going to the 255's when its time to replace my tires.
shane
Re: Tires [Re: 70rrclone] #152364
11/17/08 03:00 PM
11/17/08 03:00 PM
Mesa, Az
GETX Offline OP
GETX  Offline OP
Mesa, Az
Thanks 70rrclone for the info. I will proceed with the 255/60's
Thanks again
Re: Tires [Re: GETX] #152365
11/17/08 06:21 PM
11/17/08 06:21 PM
Rome, Ga
sbhpcb Offline
sbhpcb  Offline
Rome, Ga
I think you should also consider the wheel width and backspacing as factory wheels are different than repop's etc. You might order 2 tires and check on front if they scrubb you could move to the rear and put smaller ones on the front. Just a thought! Good luck!
Re: Tires [Re: 70rrclone] #152366
11/17/08 06:42 PM
11/17/08 06:42 PM
USA
Suregrip391 Online content
Suregrip391  Online Content
USA
Any chance you could post pics of these for reference? Must look sweet!..:)
Re: Tires [Re: sbhpcb] #152367
11/17/08 07:50 PM
11/17/08 07:50 PM
Mesa, Az
GETX Offline OP
GETX  Offline OP
Mesa, Az
Good thought sbhpcb . I will just by 2 at a time and adjust for fit.
Re: Tires [Re: Suregrip391] #152368
11/18/08 08:33 PM
11/18/08 08:33 PM
I have 245/60/15 on front and 275/60/15 on the rear of my '70 GTX. Here is a pic.
-Russ
Re: Tires #152369
11/18/08 09:02 PM
11/18/08 09:02 PM
Mesa, Az
GETX Offline OP
GETX  Offline OP
Mesa, Az
Thanks for the info. & pic 70B7GTX. Are you happy with this set-up?, any rubbing in the front when making turns & etc?
Re: Tires [Re: GETX] #152370
11/18/08 09:12 PM
11/18/08 09:12 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I have 255x60x15's on my '69 Coronet. The rims are 15"x7", and I think the backspacing is centered 3.5"?
Plenty of space in the rear, but I think I have caught the front wheel opening trim on the front tire at the top center part when cornering at speed. I think if the front end was stiffer or taller it would not be a problem, or if the rims had a bit more back space? On the other hand, I could trim the inside of the whel opening trim about 1/4" and probbly not have the problem?
Re: Tires [Re: 451Mopar] #152371
11/18/08 10:15 PM
11/18/08 10:15 PM
Mesa, Az
GETX Offline OP
GETX  Offline OP
Mesa, Az
Re: Tires [Re: GETX] #152372
11/24/08 02:45 PM
11/24/08 02:45 PM
Yes, I'm happy with the setup. As far as I can tell, I have no rubs in the wheelwells, or on the steering.
Re: Tires #152373
11/24/08 07:01 PM
11/24/08 07:01 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
I have 255/60/15 on 15x7 wheels on all 4 corners on my 69 Charger R/T with no issues as well
1MYTGTX
