Re: Tire Testing with Hot Rod, Tire Rack and Hotchkis VIDEO
[Re: Skeptic]
#1523524
10/30/13 08:26 AM
10/30/13 08:26 AM
Posts: 813 Ontario,Canada
brads70
Ontario,Canada
So.... I sent DUNLOP a e-mail asking them if they have any plans on making the ZII in bigger sizes.295/40/18 Here is the reply... " From: goodyear_cr@goodyear.com on 10/29/2013 01:01 PM
Sent by: Goodyear Tire & Rubber Company Consumer Relations 728 1144 East Market Street Akron, OH 44316 Voice #: 800.321.2136 Fax #: 330.796.6829
Mr. Richmond,
Thank you for contacting our web site and considering Dunlop for your replacement tire needs. There currently are no plans to make the ZII in this size, but, I will forward your email to Marketing for consideration.
Jennifer - Consumer Relations " I didn't know Dunlop was owned by Goodyear?
[Re: Skeptic]
#1523526
10/30/13 02:38 PM
10/30/13 02:38 PM
Posts: 1,946 Olympia, Washington
tallzag
Olympia, Washington
Been using the star spec Dunlops in Lemons for years and they have always been fantastic tires. Lots of grip and the wear pretty good too. We usually get about a race and a half out of a set (average about 14 hours per race with a few 24's mixed in).
Rocket Restorations
[Re: MuuMuu101]
#1523528
10/31/13 10:41 AM
10/31/13 10:41 AM
Posts: 841 Santa Fe Springs, CA
Dan@Hotchkis
What I like seeing is how well that 4-door B-body hugs the road. Holy crap! If that's how a '70 Satellite handles with a TVS, I wonder how my Dart would handle with the proper tire sizes.
We spend a lot of time tuning our system, and are very happy with the results. A well balanced package can turn any 2 door or 4 door into a car that is an absolute riot to drive. An A body would be lighter and faster!
[Re: MuuMuu101]
#1523529
10/31/13 12:59 PM
10/31/13 12:59 PM
B-Body Bull
An old Plymouth can handle with the best of them.
[Re: Pale_Roader]
#1523531
11/07/13 11:19 PM
11/07/13 11:19 PM
Posts: 898 Georgia
72440CUDA
Georgia
Rivals it is then!
I noticed a lot of the Optima Ultimate Street cars at SEMA running the Rivals. 315's on 12" wide rims at all four corners
[Re: Mopar Mitch]
#1523536
11/09/13 02:18 PM
11/09/13 02:18 PM
Posts: 142 Petaluma, CA
JimDiesel
Petaluma, CA
The 285/35/18 is only 25.9 inches in diameter. They look too small on a B body imo.
I haven't found too many larger sizes for these tires. It looks like the best bet would be either the: BFG Rival 295/35/18 = 26.1 inch diameter Falken 295/40/18 = 27.2 inch diameter
The Nittos come in 295/45/18 but didn't test well.
All thing being equal, for handling is a square setup is better than staggered? Thoughts on if a 295/40/18 would fit on the front of a b body?
68 Road Runner 67 Coronet
[Re: JimDiesel]
#1523537
11/09/13 11:53 PM
11/09/13 11:53 PM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
The Nitto 295 probably didn't test well because it was as wide as every other brands 265. Dont buy Nittos.
I would say that a square set-up would be superior. F1 aside, most truly extreme classes end up with square set-ups, as do most ov the really fast cars (actually fast cars, not just hyped ones) i've read about. Staggered i think is done either for the look/stance, or because most cars just have less space up front.
Never owned a pre-71 B-body, but again from what i've seen, a 285-295 will fit up front. You may want the shorter tire though, height/diameter is a space-eater just as much as width. I've seen 285/50 and 295/50 (equivalents) up front on a 68-70 B, and thats on a 15" rim, where backspace would be absolutely crucial. On an 18" rim you get quite a bit more leeway, on an E-body anyways. Cant see it being different. You may have to cut/bend some sheetmetal, or other mods to make it work, but the space is there.
[Re: JimDiesel]
#1523538
11/10/13 01:40 AM
11/10/13 01:40 AM
Dan@Hotchkis
Fitting 295/40/18 615K's on the front of my Road Runner now. I like a car squared up. And I prefer to not have the rears more than 20 aspect difference.
[Re: RylisPro]
#1523540
11/10/13 12:29 PM
11/10/13 12:29 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Sandgerg's Cuda has at least a 11" wide tire on the front of his AAR. Dan cool to see you going to that fatty on the front. Im in the middle of refinishing my engine compartment and while im doing it im going to minitub the front and notch the frame rails a little just in case.
Mopar to the bone!!!
[Re: 72Swinger]
#1523542
11/10/13 01:12 PM
11/10/13 01:12 PM
Posts: 2,432 NorCal
RylisPro
NorCal
Sandberg's Cuda also has fender flares. Sorry I wasn't specific. Can a 295 Rival fit a stock Ebody Cuda front fender without much modifications?
[Re: RylisPro]
#1523543
11/10/13 03:14 PM
11/10/13 03:14 PM
72Swinger
Nebraska
I cant say, I dont have an E-body. Do what I do, just get the tire you want to run and MAKE it work.
