Electronic conversion kit #1522918
10/24/13 09:18 PM
10/24/13 09:18 PM
Tropicalcats Offline OP
Looking for the most under the hood correct electronic ignition kit for my 1970 Dodge Challenger R/T 383 4 barrel LA car. Lots of choices out there but what is the best and the most correct for my car.
Re: Electronic conversion kit [Re: Tropicalcats] #1522919
10/24/13 10:01 PM
10/24/13 10:01 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
From what I understand electronic Ing. wasn't offered in 1970. I think it might have been an option in 71 or 72. So, pertronix is the only thing available that except for one extra wire looks correct.It goes in place of the points. Get the Pertronix I and you can still use your stock coil and ballast restore. Amazon is the cheapest place to buy.
Re: Electronic conversion kit [Re: 71birdJ68] #1522920
10/24/13 10:06 PM
10/24/13 10:06 PM
I guess what I meant to say is what would look like it is not an electronic ignition since your right it was not offered on my car. I have heard the Mopar Proformance look correct.
Re: Electronic conversion kit [Re: Tropicalcats] #1522921
10/24/13 11:00 PM
10/24/13 11:00 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
The Mopar Performance ing. has a box to deal with, and you have to use the distributor that comes with it. The best option is the Pertronix unit, and it may also be cheaper.
Re: Electronic conversion kit [Re: Tropicalcats] #1522922
10/25/13 01:21 AM
10/25/13 01:21 AM
MoreParts Offline
MoreParts  Offline
I agree. The Pertronix are good, cheap, and reliable. Parts are easy to get too. I've used them over 10 years years on my cars and they are an excellent choice. Down side is there is that additional wire you need to contend with hiding.
