Charger Wheel Opening Moulding Wont Fit New Quarter #1522903
10/24/13 08:38 PM
10/24/13 08:38 PM
MA
P
Plum70Chrgr Offline OP
P
MA
Just got my new AMD quarter panel skins for my 69 Charger.
Went to check the fit of the wheel opening moulding/trim and found they don't fit well in the lower rear section. Thinking I have 2 options, slit the trim and bend further in , or slit the skin and bend it out to meet the trim.
Anyone else using AMD or any brand skins run in to this?
How do you guys think I should proceed?
Thanks for the input.
Re: Charger Wheel Opening Moulding Wont Fit New Quarter [Re: Plum70Chrgr] #1522904
10/24/13 08:44 PM
10/24/13 08:44 PM
68gtx Offline
68gtx  Offline
Are your WOM OE or after market? Either way i would adjust the molding not the Quarter. Larry J
Re: Charger Wheel Opening Moulding Wont Fit New Quarter [Re: 68gtx] #1522905
10/24/13 08:48 PM
10/24/13 08:48 PM
MA
P
P
MA
They are oem. Have 2 sets and both fit the same. Both left and right quarter skins have the exact same issue.
Re: Charger Wheel Opening Moulding Wont Fit New Quarter [Re: Plum70Chrgr] #1522906
10/24/13 09:12 PM
10/24/13 09:12 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Had the same issue with my AMD replacement fender on 1968 Charger. I was able to bend the trim enough to make work, but a better solution would have been to make a relief cut in the moulding, bend to shape, and get the stainless welded up and repolished.
Re: Charger Wheel Opening Moulding Wont Fit New Quarter [Re: 469runner] #1522907
10/24/13 11:00 PM
10/24/13 11:00 PM
WI
RestoRick Offline
RestoRick  Offline
WI
The quarter panels aren't installed yet, correct?
I'd reshape the quarter by stretching the edge with a shrinker-stretcher. 15 minute job and it'll be the factory correct shape.
Re: Charger Wheel Opening Moulding Wont Fit New Quarter [Re: RestoRick] #1522908
10/25/13 08:43 AM
10/25/13 08:43 AM
MA
P
P
MA
No, just doing preliminary fit up.
I hate the thought of modifying an OEM part to fit an aftermarket part.
The stretcher is a little beyond my means. I was more thinking cut a slit on the inner wheel well lip near the body line that doesnt match the trim. THat would then allow me to bend the panel out to meet the trim. Not sure how that will effect where the trunk drop off meets the lower part of the rear panel tho. Guess I need to get everything temporarily mounted on the car before deciding whats the best thing to do.
Was hoping to find others that have had this exact issue to see what approach they took.
THanks for the suggestions.....keep em coming.
Re: Charger Wheel Opening Moulding Wont Fit New Quarter [Re: Plum70Chrgr] #1522909
10/25/13 01:24 PM
10/25/13 01:24 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Install the qtrs properly, then fit the wheel lip moulding, if need be, used a shrinker/stretcher, to tweak the moulding, or tweak the qtr panel before install....if you don't have a shrinker/stretcher, Eastwood has a decent "backyard" set up for the home hobbiest, invest in it, it'll make fabbing stuff up a lot easier
Mike
Re: Charger Wheel Opening Moulding Wont Fit New Quarter [Re: DAYCLONA] #1522910
10/25/13 01:34 PM
10/25/13 01:34 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I'm not a body man but this is what my painter said he's had to do before.
Good job on checking these things out now. I cringe when I see posts like this when the car has a fresh coat of paint on it.
Re: Charger Wheel Opening Moulding Wont Fit New Quarter [Re: burdar] #1522911
10/26/13 10:03 AM
10/26/13 10:03 AM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
The reproduction Charger wheel lip moldings are not made of stainless steel like the originals were. They can be shaped to fit the panels easier than the OEM ones. I was able to shape them to the panels by pressing them with my thumbs. Wear a good pair of gloves while doing it.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: Charger Wheel Opening Moulding Wont Fit New Quarter [Re: Plum70Chrgr] #1522912
10/26/13 11:51 AM
10/26/13 11:51 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
The guy doing the body work on my 70 Charger had to modify the AMD quarters in this area too......you will also find the wheel house and trunk extension will not fit the quarter panel all that well either. I bought all AMD panels and still had significant problems in this area.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Charger Wheel Opening Moulding Wont Fit New Quarter [Re: DAYCLONA] #1522913
10/27/13 08:17 PM
10/27/13 08:17 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
This is close to my experience.
Install the qtrs properly, then fit the wheel lip moulding, if need be, used a shrinker/stretcher, to tweak the moulding, or tweak the qtr panel before install....if you don't have a shrinker/stretcher, Eastwood has a decent "backyard" set up for the home hobbiest, invest in it, it'll make fabbing stuff up a lot easier. Mike
..... from my '65 Satellite. I got quarter patches from Kramer, my body man spent some time tweaking them for a good fit and profile to the moldings. However, when time came to mount the arch moldings, they didn't fit even as close you show in your pic. I was tired from a long day of working on the car and just wanted it done - so....
...I screwed the "difficult" non-conforming ends in first, then carefully but forcefully moved up the stainless arch molding 'til I had it all on. All four arches needed this treatment, some holes were difficult as #&^%$$, but I got it done and they look fine.
Now I suspect that's how they were treated on the assembly line - just slam them on and get her done!
Best of luck, -Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
