69-1970 B-body Four Speed Pedals>explain the diffrence #1522742
10/24/13 11:33 AM
10/24/13 11:33 AM
Manistee, Michigan.
High Impact Offline OP
Manistee, Michigan.
I have a four speed pedal set-up from a 69 Roadrunner and I've seen ads for 1970 Pedals being for that year only! Whats the diffrence? Will a 69 set-up fit in a 1970 Roadrunner?
Can someone explain the diffrence.
Im thinking about making my new project a four speed car but Im trying to use up parts laying around from other cars I've had or parted out. This is my 1st 1970 car, everything else I've ever had has been 1969. Thanks for the help!
Re: 69-1970 B-body Four Speed Pedals>explain the diffrence [Re: High Impact] #1522743
10/24/13 01:31 PM
10/24/13 01:31 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I've never seen 68-70 B Body pedals broken down to specific year applications regarding 4 spd set ups?, I have "69" pedals from a Roadrunner in my 70 Charger,...no issues, bolted in...I know there may be some issues with the brake rod attachment hardware regarding bore sizes, depending on what type of pedal rod your using, or booster set up, but that can be an issue just swapping brake set ups in that require a different booster/pedal rod, or intermediate linkage,...often solved with a bushing, or dilling/tapping to a larger screw stud assy/etc. etc, ...worst case senario, weld the hole shut, and drill/tap the require thread to reuse your old hardware.
Mike
Re: 69-1970 B-body Four Speed Pedals>explain the diffrence [Re: DAYCLONA] #1522744
10/24/13 01:33 PM
10/24/13 01:33 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
They will interchange, but the brackets are stamped differently.
Re: 69-1970 B-body Four Speed Pedals>explain the diffrence [Re: High Impact] #1522745
10/24/13 01:50 PM
10/24/13 01:50 PM
Dayton, WA
wesgtx440 Offline
wesgtx440  Offline
Dayton, WA
As stated above, the pedals will interchange. 70 did have the neutral safety switch setup on the pedals so that may be part of the stamping changes listed.
Re: 69-1970 B-body Four Speed Pedals>explain the diffrence [Re: wesgtx440] #1522746
12/28/13 04:14 PM
12/28/13 04:14 PM
Manistee, Michigan.
Manistee, Michigan.
Well I've went and started my four speed conversion and have the 69 runner pedals all painted up and ready to install in my 70 runner but they sure dont appear that they will just bolt up.....the bracket that the steering column bolts to appears to be welded to the lower windshield frame and contains the same part the four speed pedals have to bolt the steering column in.
Anyone have a picture of a 1970 four speed pedal set-up?
Re: 69-1970 B-body Four Speed Pedals>explain the diffrence [Re: High Impact] #1522747
12/28/13 04:34 PM
12/28/13 04:34 PM
Maryville tn
67coronetman Offline
Maryville tn
Good luck with your conversion i did mine over two years ago & i just converted back to a automatic i am just more of a auto person.
The picture i posted of that pedal came out of a 70 super bee that the safty switch a friend of mine we traded all or parts he got my 4-speed stuff i got his killer 727 & stall and more i got those pedals for him to go in his 70 coronet he has my old ones in killer shape only missing that switch he may sell them if you are in need of some..
Re: 69-1970 B-body Four Speed Pedals>explain the diffrence [Re: High Impact] #1522748
12/28/13 06:11 PM
12/28/13 06:11 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
is your issue with the "bracket" that contains the pedals and spans/bolts to the master/booster/and steering column?...if so, just transfer the pedals, and the side bracket that holds the clutch pedal over to your existing "auto" bracket, perhaps you have 66-7 B body pedals?...if you could post a pic, that will help us, help you
Mike
do your pedals look like this?
Re: 69-1970 B-body Four Speed Pedals>explain the diffrence [Re: DAYCLONA] #1522749
12/28/13 07:12 PM
12/28/13 07:12 PM
Manistee, Michigan.
Manistee, Michigan.
Yes, my problem is with the bracket that houses the pedals. my housing has the same shape as the welded bracket that I showed a picture of...even has the two threaded studs that stick down to bolt the column bracket to.
I'm not home now so I don't have any pictures of what I have.
If I can transfer the pedals over then great!!
Re: 69-1970 B-body Four Speed Pedals>explain the diffrence [Re: High Impact] #1522750
12/28/13 07:26 PM
12/28/13 07:26 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
You can transfer all the pedals/pins/nuts/etc and side bracket, even if you have 66-67 B body pedals (as the main frame bracket is different in 66-7)...what 4 spd are you using 68-9?, or 70 B/E? as there is a tailshaft/mount difference?...when you get chance you should post pics of the pedals for ID
Mike
Re: 69-1970 B-body Four Speed Pedals>explain the diffrence [Re: DAYCLONA] #1522751
12/28/13 07:53 PM
12/28/13 07:53 PM
Manistee, Michigan.
Manistee, Michigan.
I'll post picutes tomorrow of what I intend to use. Thanks for all the help!
Re: 69-1970 B-body Four Speed Pedals>explain the diffrence [Re: High Impact] #1522752
12/29/13 02:02 PM
12/29/13 02:02 PM
PGH. PA.
493DRIVER Offline
493DRIVER  Offline
PGH. PA.
1970 4 speed pedals
Re: 69-1970 B-body Four Speed Pedals>explain the diffrence [Re: 493DRIVER] #1522753
12/29/13 02:03 PM
12/29/13 02:03 PM
PGH. PA.
493DRIVER Offline
493DRIVER  Offline
PGH. PA.
another shot 70 pedals
Re: 69-1970 B-body Four Speed Pedals>explain the diffrence [Re: 493DRIVER] #1522754
12/29/13 02:05 PM
12/29/13 02:05 PM
PGH. PA.
493DRIVER Offline
493DRIVER  Offline
PGH. PA.
taken apart pic
Re: 69-1970 B-body Four Speed Pedals>explain the diffrence [Re: 493DRIVER] #1522755
12/29/13 02:06 PM
12/29/13 02:06 PM
PGH. PA.
493DRIVER Offline
493DRIVER  Offline
PGH. PA.
top pic of 70 pedals
Re: 69-1970 B-body Four Speed Pedals>explain the diffrence [Re: 493DRIVER] #1522756
12/29/13 02:10 PM
12/29/13 02:10 PM
PGH. PA.
493DRIVER Offline
493DRIVER  Offline
PGH. PA.
other side
Re: 69-1970 B-body Four Speed Pedals>explain the diffrence [Re: 493DRIVER] #1522757
12/29/13 02:11 PM
12/29/13 02:11 PM
PGH. PA.
493DRIVER Offline
493DRIVER  Offline
PGH. PA.
I have pics of them painted just cant find them
Re: 69-1970 B-body Four Speed Pedals>explain the diffrence [Re: 493DRIVER] #1522758
12/29/13 08:10 PM
12/29/13 08:10 PM
Manistee, Michigan.
Manistee, Michigan.
just got home and took some pictures. this is the housing that I have.... it doesn't look like the ones that you have pictured for me.
these were supposed to have been out of a 69 Coronet RT.
Re: 69-1970 B-body Four Speed Pedals>explain the diffrence [Re: High Impact] #1522759
12/29/13 08:13 PM
12/29/13 08:13 PM
Manistee, Michigan.
Manistee, Michigan.
Another
Re: 69-1970 B-body Four Speed Pedals>explain the diffrence [Re: High Impact] #1522760
12/29/13 08:15 PM
12/29/13 08:15 PM
Manistee, Michigan.
Manistee, Michigan.
Here are the pedals
Re: 69-1970 B-body Four Speed Pedals>explain the diffrence [Re: High Impact] #1522761
12/29/13 08:25 PM
12/29/13 08:25 PM
Manistee, Michigan.
Manistee, Michigan.
I have a couple different four speed transmissions to choose from. I have an 18 spline that I have no idea what it came out of and couldn't get to the numbers as I had stuff piled on top of it.....and I have a good 23 spline out of a 72 Chally that I drove and know its a good working unit.
Here's a couple pic's.
