Building a blown RB? #1522156
10/23/13 04:52 PM
10/23/13 04:52 PM
Stockholm, Sweden
fed Offline OP
fed  Offline OP
Stockholm, Sweden
I would like to build a low maintance blown engine.
It will be on alky. A 6-71 with twin toilets.
Any tips to make it live.
Will be in my Fed or Bantam.
Maybee 800 to 850 HP.
Cuda, -70
Valiant-65 AWB,
Valiant Signet200 -65 Topchopped dragcar.
Topolino Fuel Altered.
NostalgiaFED Sold,
SuperComp Bantam Altered, Sold
Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
Re: Building a blown RB? [Re: fed] #1522157
10/23/13 05:15 PM
10/23/13 05:15 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I would like to build a low maintenance blown engine.
can you use that Low Maintenance and blown engine in the same sentence ???
Do you have an aftermarket block ? First order of business for that HP level ...
Re: Building a blown RB? [Re: JohnRR] #1522158
10/23/13 05:35 PM
10/23/13 05:35 PM
Stockholm, Sweden
fed Offline OP
fed  Offline OP
Stockholm, Sweden
No aftermarket block. I have both RB and B blocks.
Running a 498 with 720 dynoHP in the Fed, works like a charm!
Setting the valves and one oilchange every season.
Cuda, -70
Valiant-65 AWB,
NostalgiaFED Sold,
Re: Building a blown RB? [Re: fed] #1522159
10/23/13 05:56 PM
10/23/13 05:56 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I second the motion on the after market block...But at only 700hp, we make more than that on pump gas with a NA RB at 512 cubes...I would do a low deck 400 with a girdle and -500 cubes...Should make a ton of HP, problem being, the 6-71, so a non-stroked RB would be the ticket if your only using a 6-71...Is it a high end 6-71, or a plain jane one?
Friend of mine runs 4.70 with a blown RB in a Dart like a bracket car...but not with a 6-71....
Re: Building a blown RB? [Re: Dragula] #1522160
10/23/13 06:58 PM
10/23/13 06:58 PM
Stockholm, Sweden
fed Offline OP
fed  Offline OP
Stockholm, Sweden
Plain Jane typ!
Cuda, -70
Valiant-65 AWB,
NostalgiaFED Sold,
Re: Building a blown RB? [Re: fed] #1522161
10/23/13 08:19 PM
10/23/13 08:19 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Keep the motor under 450ci with the 6-71. To free up horsepower without cranking up the boost, get some ported conventional heads like Stealth, Edelbrock, etc. Use a mild cam like a Mopar 528 mechanical. locked distributor at 25deg, 8lbs boost and you'll be at 700hp with zero maintenance.
Re: Building a blown RB? [Re: Defbob] #1522162
10/23/13 08:40 PM
10/23/13 08:40 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
use the best parts you can afford, forged pistons are a must. I highly recommend our main cap and girdle kits to ward off cap walk and completely strengthen the bottom end. after that good rods are a must, I personally like H beam rods in that application.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
