Building a blown RB?
#1522156
10/23/13 04:52 PM
10/23/13 04:52 PM
Posts: 462 Stockholm, Sweden
fed
Stockholm, Sweden
I would like to build a low maintance blown engine. It will be on alky. A 6-71 with twin toilets. Any tips to make it live. Will be in my Fed or Bantam. Maybee 800 to 850 HP.
Cuda, -70 Valiant-65 AWB, Valiant Signet200 -65 Topchopped dragcar. Topolino Fuel Altered. NostalgiaFED Sold, SuperComp Bantam Altered, Sold Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
Re: Building a blown RB?
[Re: fed]
#1522157
10/23/13 05:15 PM
10/23/13 05:15 PM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
I would like to build a low maintenance blown engine.
can you use that Low Maintenance and blown engine in the same sentence ???
Do you have an aftermarket block ? First order of business for that HP level ...
[Re: JohnRR]
#1522158
10/23/13 05:35 PM
10/23/13 05:35 PM
fed
Stockholm, Sweden
No aftermarket block. I have both RB and B blocks. Running a 498 with 720 dynoHP in the Fed, works like a charm! Setting the valves and one oilchange every season.
[Re: fed]
#1522159
10/23/13 05:56 PM
10/23/13 05:56 PM
Posts: 12,391 Taxes & Virus's R-US, NY
Dragula
I second the motion on the after market block...But at only 700hp, we make more than that on pump gas with a NA RB at 512 cubes...I would do a low deck 400 with a girdle and -500 cubes...Should make a ton of HP, problem being, the 6-71, so a non-stroked RB would be the ticket if your only using a 6-71...Is it a high end 6-71, or a plain jane one?
Friend of mine runs 4.70 with a blown RB in a Dart like a bracket car...but not with a 6-71....
