gaping the plugs with MSD #1521708
10/22/13 09:28 PM
10/22/13 09:28 PM
Hermiston Oregon
mopar_leaner Offline OP
Hermiston Oregon
any ideas about gaping the plugs in a BB with 180psi cylinder pressure and a MSD StreetFire ignition box?
( it takes a Mopar, to beat a Mopar!
email me at moparleaner@gmail.com )
Re: gaping the plugs with MSD [Re: mopar_leaner] #1521709
10/22/13 09:37 PM
10/22/13 09:37 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I have my plugs gapped to .045 with the Streetfire box.
EDIT:
MSD Blaster High Vibration Coil
Re: gaping the plugs with MSD [Re: YO7_A66] #1521710
10/22/13 09:42 PM
10/22/13 09:42 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
.045 on mine, I think with normal run of the mill plugs that's about all they will open and still be parallel electrode to strap.
Re: gaping the plugs with MSD [Re: ademon] #1521711
10/22/13 10:27 PM
10/22/13 10:27 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
.045 with my 6al, I know I could go larger, but I doubt there would be any benefit.
Re: gaping the plugs with MSD [Re: Pacnorthcuda] #1521712
10/23/13 09:16 AM
10/23/13 09:16 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
.045 with the 2 setups we have also.Been running that for years.Rocky
Chrysler Firepower
Re: gaping the plugs with MSD [Re: therocks] #1521713
10/23/13 09:23 AM
10/23/13 09:23 AM
Hermiston Oregon
Hermiston Oregon
to all,
thank you very much.... .045 it is!!!
Re: gaping the plugs with MSD [Re: mopar_leaner] #1521714
10/23/13 07:24 PM
10/23/13 07:24 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
umm, the coil fires the plugs not the box. while a .45 is great for say a blaster2 coil it might cause problems with a stock coil. all the box does is tell the coil to fire. or i'm confused. the multi-spark of a MSD ECU might not allow a stock coil to 'recharge' enough to bridge a .45 gap repeatedly. just thinking out loud.......
Re: gaping the plugs with MSD [Re: mikemee1331] #1521715
10/24/13 09:21 AM
10/24/13 09:21 AM
Hermiston Oregon
Hermiston Oregon
Good news, the coil is a blaster by MSD, so we are set with the gaps at .045.
Re: gaping the plugs with MSD [Re: mopar_leaner] #1521716
10/24/13 11:03 AM
10/24/13 11:03 AM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
The box also plays a big role in the quality of the spark. It must be able to drive enough current to handle the coil being used (some coils have low impedance and deliver high secondary current). The rate at which the box interrupts the current also directly affects secondary voltage level.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
