Re: i want to redrill my small axles to large bolt pattern [Re: Dave Watt] #1521595
10/24/13 02:22 PM
10/24/13 02:22 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Moser makes an axle that will use redrilled SBP drum/brakes with a 4.5" BBP circle.
Dr. Diff is a great choice if swapping brakes to the BBP set up. He may have the same axle as moser available to use the SBP brakes.
Re: i want to redrill my small axles to large bolt pattern [Re: Cab_Burge] #1521596
10/24/13 02:25 PM
10/24/13 02:25 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
... I have had several sets of A body axles done by a shop in SO CA years ago, he made a mandrel that centered on the small axle register with the large 4.5 inch bolt pattern in it and then transferred the pattern to those axles, he would drill and tap them for 1/2 inch by 20 threads screw in studs Those worked good, lasted a long time, same thing on the brake drums, same pattern
Mine were done at the same place 20 years and 80K hard hard miles ago.
I paid Mazzolini for it. But really he just farmed it out to Sutton Engineering I found out years later. Mazzolini didn't do much directly in house. Just put together the right resources.
Re: i want to redrill my small axles to large bolt pattern [Re: Rhinodart] #1521597
10/24/13 02:36 PM
10/24/13 02:36 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Drilling and tapping using screw in studs leaves very near as much meat around the stud as the OEM original knurled pressed in studs
The axles on my sons Dart were drilled to the large pattern and has screw in studs. It was done in 1997 and the axles are still in the car. It has been raced and driven over the years with no problems. Ron
You guys need to quit making sense.
I've done the same thing. Launching off a transbrake and running sub 1.50 60's.
Run stud centric wheels.
Both my failures were on the street turning quick corners, not nearly the same loads on drag cars...
I've done all kind of autocrossing and high speed track days with mine. Driven 1600 miles in 40 hours and overloaded car to 5600 lbs once. Lots of other long trips.
Been off track a few times at high speed. Bent front steel rim once and twice had to have my rear tires dismounted and remounted to remove the chunks of earth wedged between the tire and rim bead.
The corners are long enough and fast enough that the rear end will puke diff oil out the little factory breather.
Going directly sideways against the axle over desert terrain at 70mph or so...
http://m.youtube.com/watch?v=XJW-YvipFYE...mp;ved=0CA0QqwQ
But nowdays I would have just got real BBP axles. Makes life easier for brakes.
Re: i want to redrill my small axles to large bolt pattern [Re: MoparforLife] #1521598
10/24/13 06:08 PM
10/24/13 06:08 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Too close to the edge, I'm frugal and would not even consider it after looking into it.
Pick up some truck or a set of C-body axles and have Moser work their magic or if you are a fan of sealed bearings (I'm NOT) get some aftermarket axles.
Not if you usse screw in studs. There is all most as much meat around the stud as the large holed knurled type. You will break a stud before you break the flange.
Sorry but I agree with Rick here, rather have the factory stuff and no oddball parts. Its stronger and easier to lay hands on in the event of an emergency.
"I think its got a hemi"
Re: i want to redrill my small axles to large bolt pattern [Re: autoxcuda] #1521599
10/24/13 08:09 PM
10/24/13 08:09 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
My failures were long before screw-in studs were available, so I cannot comment on how good they are.
JB Rhinehart, Realist
A-Body's RULE!
Re: i want to redrill my small axles to large bolt pattern [Re: Rhinodart] #1521600
10/24/13 09:42 PM
10/24/13 09:42 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Grade 8 socket cap screws. Been around forever.
Re: i want to redrill my small axles to large bolt pattern [Re: BSB67] #1521601
10/24/13 10:26 PM
10/24/13 10:26 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I did this years ago and just had Moser do it. Wasn't much money and zero issues.
If you are in Cincy they aren't a terribly long way away.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: i want to redrill my small axles to large bolt pattern [Re: RobX4406] #1521602
10/24/13 10:30 PM
10/24/13 10:30 PM
Moser told me to hook my tape over the flange & if I have 28" or more before it starts to neck down then it is a suitable condidate to get shortened to A body specs
Re: i want to redrill my small axles to large bolt pattern [Re: BSB67] #1521603
10/25/13 12:58 AM
10/25/13 12:58 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Yep, that's what mine are. Just grade 8 socket cap screws.
Re: i want to redrill my small axles to large bolt pattern [Re: autoxcuda] #1521604
10/25/13 01:12 AM
10/25/13 01:12 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
30plus years ago we re-drilled them. Back then, an aftermarket set of axles was $300, almost the same as what they can be bought for today.
We used a lathe to scribe a 4.5" circle on the flange, then drilled and tapped 1/2"X20 holes every 72*.
With the price of axles today, there's no way I'd bother re-drilling. Just the advantage of brake choice is worth the price of the axles. Why stick with expensive, hard to find 10"X1.75" brakes when you can upgrade to cheap and plentiful 10"X2", or larger, brakes.
Do yourself a favor and call Dr Diff.
Re: i want to redrill my small axles to large bolt pattern [Re: B5 Bee] #2747815
02/29/20 05:38 PM
02/29/20 05:38 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Just got the axles back from Moser today w screw in studs installed it was $90 to do the pair. They look great, can't hardly tell where the old holes where and they obviously put em in a lathe and trued both sides of the flange. Very happy w their work.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: i want to redrill my small axles to large bolt pattern [Re: HemiRick] #2747972
03/01/20 11:01 AM
03/01/20 11:01 AM
moparx Offline
moparx  Offline
glad it worked out for you ! up
beer
