i want to redrill my small axles to large bolt pattern #1521575
10/22/13 05:07 PM
10/22/13 05:07 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
i know people do it, i know it can be done,
does someone offer a template to do so?
Re: i want to redrill my small axles to large bolt pattern [Re: mcat4321] #1521576
10/22/13 05:59 PM
10/22/13 05:59 PM
Maybe, maybe not. The larger bolt pattern axles also have a lrger center register so you can't easily take a 4.5 inch bolt pattern wheel and lay it on the small pattern axle and use it as a pattern I have had several sets of A body axles done by a shop in SO CA years ago, he made a mandrel that centered on the small axle register with the large 4.5 inch bolt pattern in it and then transferred the pattern to those axles, he would drill and tap them for 1/2 inch by 20 threads screw in studs Those worked good, lasted a long time, same thing on the brake drums, same pattern
Re: i want to redrill my small axles to large bolt pattern [Re: mcat4321] #1521577
10/22/13 06:46 PM
10/22/13 06:46 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
You don't need a template if you use a mill.
I have built wheel spacers before with a bridgeport mill.
Re: i want to redrill my small axles to large bolt pattern [Re: Challenger 1] #1521578
10/22/13 06:52 PM
10/22/13 06:52 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Back in the day I ruined a couple sets of axles and wheel wells. I would never weaken the axle nowadays with plenty of big bolt axles available aftermarket. Talk with Dr. Diff.
JB Rhinehart, Realist
A-Body's RULE!
Re: i want to redrill my small axles to large bolt pattern [Re: Rhinodart] #1521579
10/22/13 09:23 PM
10/22/13 09:23 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Drilling and tapping using screw in studs leaves very near as much meat around the stud as the OEM original knurled pressed in studs
Re: i want to redrill my small axles to large bolt pattern [Re: mcat4321] #1521580
10/23/13 12:24 AM
10/23/13 12:24 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
You'll still have the small center register, so no wheels will pilot, and you'll have oddball drums. If you're bucks-down, just take a chop saw to C-body or pickup axle shafts.
Rick
Re: i want to redrill my small axles to large bolt pattern [Re: Rick_Ehrenberg] #1521581
10/23/13 02:43 AM
10/23/13 02:43 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Rick
Most aftermaket wheels don't center on the register anyway.
Would I do it with stock wheels or on a race car? No.
Street car with aftermarket wheels? Sure.
Re: i want to redrill my small axles to large bolt pattern [Re: Rick_Ehrenberg] #1521582
10/23/13 03:01 AM
10/23/13 03:01 AM
Hawaii
Dodgeballs Offline
Dodgeballs  Offline
Hawaii
Rick
Can any C-Body axles be cut to fit the A-Body 8 3/4? How much needs to be cut? What year trucks? I have re-drilled A-body axles right now, but would like the big register. I would still have to use the A-body drums and re-drill them, right?
Re: i want to redrill my small axles to large bolt pattern [Re: Dodgeballs] #1521583
10/23/13 03:47 AM
10/23/13 03:47 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
The axles on my sons Dart were drilled to the large pattern and has screw in studs. It was done in 1997 and the axles are still in the car. It has been raced and driven over the years with no problems. Ron
Re: i want to redrill my small axles to large bolt pattern [Re: Dodgeballs] #1521584
10/23/13 06:21 AM
10/23/13 06:21 AM
Marlboro, NY, USA
Marlboro, NY, USA
Rick
No, you'd use brakes (complete) from any "big bolt" 8-3/4" (or even 8.25 / 9.25" with the same bolt pattern).
I used to have the data showing which donors had enough spline length to cut, but I cannot find it. Hopefully someone else will chime in.
Also inexpensive new axles are made specifically for this swap (Yukon, etc.)
Rick
Re: i want to redrill my small axles to large bolt pattern [Re: Rick_Ehrenberg] #1521585
10/23/13 09:46 AM
10/23/13 09:46 AM
NC
SLOW67 Offline
SLOW67  Offline
NC
Just call Dr. Diff. His axle packages are very reasonable and slide right in with no issues, If I can afford them anyone can lol I'm the king of cheap
Re: i want to redrill my small axles to large bolt pattern [Re: SLOW67] #1521586
10/23/13 10:54 AM
10/23/13 10:54 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Like I said above after losing a couple redrilled axles (your use may vary) I sent a pair of C-Body axles to Moser to have them cut and resplined (this was in 1980) and used the 11" C-Body brakes and never looked back. Now that there are plenty of ready to use axles I would go this route today.
A-Body's RULE!
Re: i want to redrill my small axles to large bolt pattern [Re: MoparforLife] #1521587
10/23/13 11:18 AM
10/23/13 11:18 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
You guys need to quit making sense.
I've done the same thing. Launching off a transbrake and running sub 1.50 60's.
Run stud centric wheels.
Re: i want to redrill my small axles to large bolt pattern [Re: RobX4406] #1521588
10/23/13 06:03 PM
10/23/13 06:03 PM
Upper Midwest
Upper Midwest
Run stud centric wheels. I was launching foot break but 1.50ish 60's too and never had a problem and as far as I know is still going. Redrilled the brake drums also.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: i want to redrill my small axles to large bolt pattern [Re: RobX4406] #1521589
10/23/13 07:20 PM
10/23/13 07:20 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Both my failures were on the street turning quick corners, not nearly the same loads on drag cars...
A-Body's RULE!
Re: i want to redrill my small axles to large bolt pattern [Re: Rhinodart] #1521590
10/24/13 06:45 AM
10/24/13 06:45 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Too close to the edge, I'm frugal and would not even consider it after looking into it.
Pick up some truck or a set of C-body axles and have Moser work their magic or if you are a fan of sealed bearings (I'm NOT) get some aftermarket axles.
"I think its got a hemi"
Re: i want to redrill my small axles to large bolt pattern [Re: gdonovan] #1521591
10/24/13 01:14 PM
10/24/13 01:14 PM
Upper Midwest
Upper Midwest
Not if you usse screw in studs. There is all most as much meat around the stud as the large holed knurled type. You will break a stud before you break the flange.
Re: i want to redrill my small axles to large bolt pattern [Re: MoparforLife] #1521592
10/24/13 02:16 PM
10/24/13 02:16 PM
Actully you will twist the left side axle splines off and break the axle first before the screw in studs give you any problems, trust me on that Many 10.60 ET at 3150 lbs for many laps on A body axles before they broke
Re: i want to redrill my small axles to large bolt pattern [Re: Dodgeballs] #1521593
10/24/13 02:17 PM
10/24/13 02:17 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
No. There are only a few years in the early '70's that will work, and they are usually in a C-body wagon. The only way you can tell is that just past the splines will be the same diameter at the splines. Most are a smaller diameter in that area preventing them from being resplined.
Re: i want to redrill my small axles to large bolt pattern [Re: mcat4321] #1521594
10/24/13 02:20 PM
10/24/13 02:20 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
