Re: i want to redrill my small axles to large bolt pattern
[Re: Cab_Burge]
#1521596
10/24/13 02:25 PM
10/24/13 02:25 PM
Posts: 27,465 So Cal
autoxcuda
So Cal
... I have had several sets of A body axles done by a shop in SO CA years ago, he made a mandrel that centered on the small axle register with the large 4.5 inch bolt pattern in it and then transferred the pattern to those axles, he would drill and tap them for 1/2 inch by 20 threads screw in studs Those worked good, lasted a long time, same thing on the brake drums, same pattern
Mine were done at the same place 20 years and 80K hard hard miles ago.
I paid Mazzolini for it. But really he just farmed it out to Sutton Engineering I found out years later. Mazzolini didn't do much directly in house. Just put together the right resources.
[Re: Rhinodart]
#1521600
10/24/13 09:42 PM
10/24/13 09:42 PM
Posts: 4,311 Prospect, PA
BSB67
Prospect, PA
Drilling and tapping using screw in studs leaves very near as much meat around the stud as the OEM original knurled pressed in studs
The axles on my sons Dart were drilled to the large pattern and has screw in studs. It was done in 1997 and the axles are still in the car. It has been raced and driven over the years with no problems. Ron
You guys need to quit making sense.
I've done the same thing. Launching off a transbrake and running sub 1.50 60's.
Run stud centric wheels.
Both my failures were on the street turning quick corners, not nearly the same loads on drag cars...
I've done all kind of autocrossing and high speed track days with mine. Driven 1600 miles in 40 hours and overloaded car to 5600 lbs once. Lots of other long trips.
Been off track a few times at high speed. Bent front steel rim once and twice had to have my rear tires dismounted and remounted to remove the chunks of earth wedged between the tire and rim bead.
The corners are long enough and fast enough that the rear end will puke diff oil out the little factory breather.
Going directly sideways against the axle over desert terrain at 70mph or so...
http://m.youtube.com/watch?v=XJW-YvipFYE...mp;ved=0CA0QqwQ
But nowdays I would have just got real BBP axles. Makes life easier for brakes.
My failures were long before screw-in studs were available, so I cannot comment on how good they are.
Grade 8 socket cap screws. Been around forever.
[Re: BSB67]
#1521601
10/24/13 10:26 PM
10/24/13 10:26 PM
Posts: 11,709 Portage,michigan
B3422W5
Portage,michigan
I did this years ago and just had Moser do it. Wasn't much money and zero issues. If you are in Cincy they aren't a terribly long way away.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: RobX4406]
#1521602
10/24/13 10:30 PM
10/24/13 10:30 PM
RapidRobert
Moser told me to hook my tape over the flange & if I have 28" or more before it starts to neck down then it is a suitable condidate to get shortened to A body specs
[Re: BSB67]
#1521603
10/25/13 12:58 AM
10/25/13 12:58 AM
autoxcuda
So Cal
Yep, that's what mine are. Just grade 8 socket cap screws.
[Re: autoxcuda]
#1521604
10/25/13 01:12 AM
10/25/13 01:12 AM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
30plus years ago we re-drilled them. Back then, an aftermarket set of axles was $300, almost the same as what they can be bought for today. We used a lathe to scribe a 4.5" circle on the flange, then drilled and tapped 1/2"X20 holes every 72*.
With the price of axles today, there's no way I'd bother re-drilling. Just the advantage of brake choice is worth the price of the axles. Why stick with expensive, hard to find 10"X1.75" brakes when you can upgrade to cheap and plentiful 10"X2", or larger, brakes.
Do yourself a favor and call Dr Diff.
[Re: B5 Bee]
#2747815
02/29/20 05:38 PM
02/29/20 05:38 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Just got the axles back from Moser today w screw in studs installed it was $90 to do the pair. They look great, can't hardly tell where the old holes where and they obviously put em in a lathe and trued both sides of the flange. Very happy w their work.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
