Mopar 3462346 head #1521559
10/22/13 05:04 PM
10/22/13 05:04 PM
Ont, Canada
gygeneral Offline OP
Ont, Canada
Do these heads with casting number 3462346 have hardened valve seats?
Thanks for your replies
Re: Mopar 3462346 head [Re: gygeneral] #1521560
10/22/13 05:32 PM
10/22/13 05:32 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
No 452s are the ones you're looking for
Re: Mopar 3462346 head [Re: GTX MATT] #1521561
10/22/13 05:37 PM
10/22/13 05:37 PM
Ont, Canada
Ont, Canada
I was asking because I'm just planning the rebuilding of my 440-6 motor in my RR and these are the heads on it. So I guess I must get the seats done to run with today's fuel right?
Re: Mopar 3462346 head [Re: gygeneral] #1521562
10/22/13 05:51 PM
10/22/13 05:51 PM
Cab_Burge Online work
Cab_Burge  Online Work
Not neccessarily, if you have standard OEM exhaust valves yes you should If they are replacemnt stainess steel valves probally not I have a bunch of pump gas motors out there with 906 heads and 1.81 stainless steel replacement exhaust valves along with new stainless steel 2.14 intake valves, no complaints on the valves burning up or tulliping on pump gas so far It can't hurt to have harden seats put in them and larger valves, if you want both more performance and longivity
Re: Mopar 3462346 head [Re: Cab_Burge] #1521563
10/22/13 07:17 PM
10/22/13 07:17 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Yes air on the safe side and have seats put in for longivity. Also have the shop that does the work, remove the step out of the exhaust pocket and blend it after they install the new hard seat.
MLR426
Re: Mopar 3462346 head [Re: MLR426] #1521564
10/22/13 07:55 PM
10/22/13 07:55 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
FWIW Alan Gallant has a pair of hot-tanked, magnafluxed, uncut 346 heads for $100 on Kijiji
Cheaper than putting your own heads through the same process...
Re: Mopar 3462346 head [Re: YYZ] #1521565
10/22/13 11:52 PM
10/22/13 11:52 PM
Ont, Canada
Ont, Canada
Ok that answers my question.
YYZ thanks for the tip, I will talk to my engine builder about those heads.
Thanks for the help
Re: Mopar 3462346 head [Re: gygeneral] #1521566
10/23/13 12:22 AM
10/23/13 12:22 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Any Chrysler heads cast after mid-1972 have induction hardened exhaust seats.
Rick
Re: Mopar 3462346 head [Re: Rick_Ehrenberg] #1521567
10/23/13 02:59 PM
10/23/13 02:59 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
346s were the first ones (1971) with induction hardened seats.. The 452s were the next evolution. I would put seats into it because the valve job will grind through it.
Re: Mopar 3462346 head [Re: moper] #1521568
10/23/13 11:31 PM
10/23/13 11:31 PM
I find that hard to believe Ethyl additives where in all kinds of fuel sold in 1971, I don't remember excatly when the lead was removed from pump gas but I'm sure it was after 1971 I'm almost sure that the 346 head was a one year only head
Re: Mopar 3462346 head [Re: Cab_Burge] #1521569
10/24/13 12:17 PM
10/24/13 12:17 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
I insist on putting new seats in 346 heads when used with unleaded fuel, as they are still pre-unleaded era heads. The lead came out I believe after 73, research it and lets see. To me the gamble isn't worth betting on.
MLR426
Re: Mopar 3462346 head [Re: MLR426] #1521570
10/24/13 04:05 PM
10/24/13 04:05 PM
SoCal
jake4cars Offline
jake4cars  Offline
SoCal
I thought 346's did have hardened seats from the factory. I know from porting them that they make good horsepower. On an unleaded engine I would use 346's or 452's any day.
Joey
Re: Mopar 3462346 head [Re: jake4cars] #1521571
10/24/13 07:04 PM
10/24/13 07:04 PM
Ont, Canada
Ont, Canada
Just took the heads today to the machine shop to get hot tanked. Once clean should see better what we have.
Re: Mopar 3462346 head [Re: gygeneral] #1521572
10/24/13 07:16 PM
10/24/13 07:16 PM
dogdays Offline
dogdays  Offline
On my 213s, which are I believe 1973s, after hot tanking it was easy to see rings of discoloration around the valve seats. But your heads are earlier and I'll bet no hardening of seat areas was done.
From 346 through 452, the ports are all the same, according to many who have worked on them. Find Steve Dulcich's three part article on bigblock Mopar heads, it is pretty definitive.
R.
Re: Mopar 3462346 head [Re: jake4cars] #1521573
10/24/13 08:00 PM
10/24/13 08:00 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Joey
The 346's on my 71 engine had them from the factory.
Re: Mopar 3462346 head [Re: gygeneral] #1521574
10/24/13 08:03 PM
10/24/13 08:03 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
906Fs are the way to go. Best flowing of the big block heads
