Re: Mopar 3462346 head
[Re: gygeneral]
#1521560
10/22/13 05:32 PM
10/22/13 05:32 PM
Posts: 5,162 CT
GTX MATT
CT
No 452s are the ones you're looking for
[Re: GTX MATT]
#1521561
10/22/13 05:37 PM
10/22/13 05:37 PM
Posts: 1,053 Ont, Canada
gygeneral
Ont, Canada
I was asking because I'm just planning the rebuilding of my 440-6 motor in my RR and these are the heads on it. So I guess I must get the seats done to run with today's fuel right?
[Re: Cab_Burge]
#1521563
10/22/13 07:17 PM
10/22/13 07:17 PM
Posts: 4,799 ILL
MLR426
ILL
Not neccessarily, if you have standard OEM exhaust valves yes you should If they are replacemnt stainess steel valves probally not I have a bunch of pump gas motors out there with 906 heads and 1.81 stainless steel replacement exhaust valves along with new stainless steel 2.14 intake valves, no complaints on the valves burning up or tulliping on pump gas so far It can't hurt to have harden seats put in them and larger valves, if you want both more performance and longivity
Yes air on the safe side and have seats put in for longivity. Also have the shop that does the work, remove the step out of the exhaust pocket and blend it after they install the new hard seat.
MLR426
[Re: Rick_Ehrenberg]
#1521567
10/23/13 02:59 PM
10/23/13 02:59 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
346s were the first ones (1971) with induction hardened seats.. The 452s were the next evolution. I would put seats into it because the valve job will grind through it.
[Re: jake4cars]
#1521573
10/24/13 08:00 PM
10/24/13 08:00 PM
Posts: 843 Suffolk,VA
ireland383
Suffolk,VA
I thought 346's did have hardened seats from the factory. I know from porting them that they make good horsepower. On an unleaded engine I would use 346's or 452's any day.
Joey
The 346's on my 71 engine had them from the factory.
