'70 Bench Seat Tracks... same as '68/'69?? #152152
11/17/08 11:17 AM
11/17/08 11:17 AM
Jacksonville, Fl
426runner Offline OP
Jacksonville, Fl
Are '68 to '70 Bbody bench seat tracks the same or are there differences year to year?
Later, Sandy '70 HEMI Road Runner B5/B5, 4 spd "Sandy's Garage" on Facebook
Re: '70 Bench Seat Tracks [Re: 426runner] #152153
11/17/08 11:51 AM
11/17/08 11:51 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I know buckets are different for 68/69 versues 70 . Not sure on the bench seat versions, at least here's a bump for ya
Re: '70 Bench Seat Tracks [Re: 426runner] #152154
11/18/08 09:18 AM
11/18/08 09:18 AM
Jacksonville, Fl
Jacksonville, Fl
OK, let's try this... are 4 door bench tracks the same as 2 door bench tracks??
Re: '70 Bench Seat Tracks [Re: 426runner] #152155
11/18/08 10:02 AM
11/18/08 10:02 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Floor pan is the same,I assume (and you know what they say about "assume") that the tracks are the same.
Re: '70 Bench Seat Tracks [Re: 426runner] #152156
11/19/08 04:06 PM
11/19/08 04:06 PM
Lakewood, WA
rick@laysons Offline
Lakewood, WA
Yes, they are the same.
Re: '70 Bench Seat Tracks [Re: rick@laysons] #152157
11/19/08 05:08 PM
11/19/08 05:08 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
No they are not, according to the part #'s. I have always been told they are different also. Possible they may bolt up and work but there is some kind of difference or they would have the same part #'s
Re: '70 Bench Seat Tracks [Re: rrunner] #152158
11/19/08 06:05 PM
11/19/08 06:05 PM
Lakewood, WA
Lakewood, WA
They may very well have different part numbers, but I do know from first hand experience that the bench seat tracks out of a 69 Coronet four door I parted out worked just fine in my 70 RoadRunner. They fit and functioned just like they should.
Re: '70 Bench Seat Tracks [Re: rick@laysons] #152159
11/19/08 06:33 PM
11/19/08 06:33 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Never said they wouldn't work, but the #'s are different so they can't be the same tracks as stated earlier.
Re: '70 Bench Seat Tracks [Re: rrunner] #152160
11/20/08 10:34 AM
11/20/08 10:34 AM
Indiana USA
DBishop68 Offline
DBishop68  Offline
Indiana USA
4 door tracks will work but are a bit taller about 5/8 maybe 3/4 of an inch
Re: '70 Bench Seat Tracks [Re: DBishop68] #152161
11/20/08 01:51 PM
11/20/08 01:51 PM
CANADA
Desmond Offline
Desmond  Offline
CANADA
where can the number be found on the track? Anyone got a pic to post? I have a box of tracks that I believe are mostly 1970 to sort through. Help would be appreciated. thanks
"Been spending all my nights on the internet, looking for a clue that I ain't found yet, just a bunch of Mopars, guitars and other s#*t i can't buy." - Sturgill Simpson
Re: '70 Bench Seat Tracks [Re: Desmond] #152162
11/20/08 02:44 PM
11/20/08 02:44 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
This set is from my 68 Road Runner bench seat. Tracks are installed now so no way to easily check for #s. Hope this helps.
68 Hemi Road Runner
Re: '70 Bench Seat Tracks [Re: rick@laysons] #152163
11/24/08 04:24 PM
11/24/08 04:24 PM
O
OLD318 Offline
OLD318  Offline
O
PARTS VENDORS WILL TELL YOU THESE ARE THE SAME
Sorry Laysons... THEY ARE NOT!!!
I have personally owned both a 70 Coronet 2 door
and a 70 coronet 4 door...
The tracks look very,very similar as do the bench portions of the seats...
but they are NOT THE SAME...
For the record, I am looking at a factory parts book for 70-71...
The part numbers listed in the parts book for the 70 Coronet with a split bench seat are
DIFFERENT than the 70 4 door versions...
Now given that..
You should ask 3 questions..
1) Will 4 door seat tracks pulled from a 70
Coronet 4 door physically fit in the
70 Coronet 2 door car in the floor pan..
WITHOUT ANY MODIFICATIONS? (i.e drilling)
The answer is: YES
2) Will the 4 door tracks attach to the 2 door
bench seat in the exact same positions?
I don't know this.. you'd have to try it...
3) Will the 70 Coronet 2 door split bench seat
with 70 coronet4 door seat tracks attached to
them lay the same once in a 2 door car?
(i.e seating angle)
Not exactly!
The 4 door bench is physically a different seat than the 2 door split bench seat. Again they look very similar...
I have had both off of their tracks laying on
a garage floor..they lay differently!
The 2 door bench seat cover will not fit a 4 door bench seat or vice-versa...
The ultimate question is can you get them
installed and get them to work
Most likely YES...
Can you live with the differences: Probably..
But they are different....
Re: '70 Bench Seat Tracks [Re: OLD318] #152164
11/24/08 05:04 PM
11/24/08 05:04 PM
Lakewood, WA
Lakewood, WA
OLD318, please note that I was NOT responding to this post as a vendor, I was merely giving first-hand experience that I had with my own cars. No where in my post did I EVER offer to sell, or in any way, shape, or form promote a sale of any kind in my reply.
Again, I'll say this loud and clear, I was only giving my first hand experience with my own cars and in no way was the fact that I happen to work for Layson's brought into this subject until you yourself did so.......period.
Take that for what it's worth......
Re: '70 Bench Seat Tracks [Re: rick@laysons] #152165
11/25/08 01:07 PM
11/25/08 01:07 PM
O
OLD318 Offline
OLD318  Offline
O
Rick, please forgive my trespass..
I'm not trying to start anything here
The simple fact is:
1) You are a vendor.
2) You did respond in writing with the above
statement:
"Yes, they are the same."
What would you reasonably expect an
unassumming car owner to think given that statement from a parts vendor such as yourself?
"Yes, they are the same"
as opposed to something more accurate like:
"They are not exactly the same
but you can get them to work"
The first statement implies identical..
The 2nd statement does not...
