Question about alignment of steering arm
#152118
11/17/08 08:46 AM
11/17/08 08:46 AM
Posts: 4,288 Danville, NH
Mopar_Mike
Danville, NH
I am putting a new manual steering box into my 67 Coronet. I know the pitman arm can only go on the box one way, but at what position do you put it through the center link? Years ago I turned the wheels all the way one way and then the box all the way that way and then hooked it up. This did not work though as it was about a 60/40 turn ratio rather than a 50/50. Thanks.
RS23L7 4-Speed
Re: Question about alignment of steering arm
[Re: Mopar_Mike]
#152119
11/17/08 08:54 AM
11/17/08 08:54 AM
unless they have a different setup on 67 coronets, that connection to the centerlink is by a ball and socket type connection. the ball and stud will rotate in the socket on the pitman arm. so it doesnt need any special alignment
[Re: Mopar_Mike]
#152123
11/17/08 10:59 AM
11/17/08 10:59 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
to fix that the tie rods would have had to been adjusted properly , the steering box needs to be centered FIRST , the pitman arm is keyed as is the steering column connection .
